From L98 block to L31??
Car: 91Z
Engine: 355/afr/sr/lpe219
Transmission: built 700R
I have an eagle 1pc rear main crank, 6'' rods and forged pistons for my L98. Assuming the blocks have the same bore, will all of these parts work?? Is the timing chain and cover compatable?? Any other surprises? Any help is welcome at this point!!
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
Yup all the same stuff. The one thing I'm not sure about is aren't L31 flat-tappet blocks? That would pretty much be the only difference. That would make your timing chain incompatible.
RyanJB
Sep 14, 2015 03:39 PM
