Heated O2 senor installation
Old Jun 23, 2004 | 10:19 AM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
I want to install a heated O2 sensor in my 85 IROC. How do you hook up the heater wire? Do you tie it into a "keyed" hot wire or what????
Old Jun 23, 2004 | 09:11 PM
Vader's Avatar
This is one method:
Old Jun 24, 2004 | 09:14 AM
Captain C's Avatar
Car: 1985 IROC-Z
Which ECM is in the picture???? I am currently running the original 870 computer. If the computer in the picture is a 165, I have the wiring diagrams for both and can make the correct connections to the computer.
Old Jun 24, 2004 | 09:35 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
You can just tie it into a hot-when-key-is-on wire if you don't prefer the high tech relay driven method Vader posted. His is probably the best method, but the key-hot-wire may be easier....
Old Jun 24, 2004 | 03:03 PM
Captain C's Avatar
Car: 1985 IROC-Z
The keyed hot wire may be the best thing to do for now.... I can always upgrade later.....
junior419
Apr 7, 2025 11:35 AM
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
85 Jimmy
Sep 30, 2015 07:56 AM
BLK87Z
Sep 18, 2015 11:29 PM
