Car wont idle and dies when i let off the gas and hit the clutch
Old Jun 23, 2004 | 05:53 PM
Leader_One's Avatar
Car: 1990 TA, 1995 Sierra 1500
Engine: 305tpi to LT1 mod, 305 TBI
Transmission: 4L60E with 3000 Stall, 5spd
Well my car wont idle properly when i start it up. I have to hit the gas just to get it to idle and when it does idle it idles at like 500 rpms. It also dies on the road when i let off the gas and hit the clutch. My friend says that it needs a tuneup so thats what im about to do. I ordered a fuel filter, spark plugs, wireset, 02 sensor, distributor cap, and distributor rotor. Do you guys think that this should do the trick or is it something else?
Old Jun 23, 2004 | 06:50 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
Yeah either a tune up or just increase the idle speed.... should be a screw to increase the idle speed depending on what carb you have. Most likely a tune up is worth doing as an engine should survive at 500rpm just....
Si.
1992 Trans Am
May 10, 2023 07:19 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
Wade787b
Sep 29, 2015 01:15 PM
