L69 w/TPI swap suggestions?
Old Jun 24, 2004 | 12:56 PM
whitess's Avatar
Car: 85 SS
Engine: 305 L69
Transmission: 2004R
Axle/Gears: 7.625, 3.73
I want to put the SD TPI on my '85 L69 (Monte Carlo SS). I'll keep the stock cam and automatic w/3.73's. Other than a custom chip any other suggestions/recommendations (distributor, torque converter, etc)? This will be just a street car.
Thanks,
Larry.
Old Jun 24, 2004 | 03:25 PM
GASGZLR's Avatar
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
If your L69 has the stock cam and heads you should try to find a TPI off a 85 TPI 305 with an auto. The computer should already be tuned to that setup. It is a mass air setup. I believe the L69 and the 85 LB9 had the same cam in them. The "soon to be" L98 cam. Only the 85 motors had the flat tappet versions of the L98 cam.
theshackle
Mar 5, 2017 06:37 PM
Chuck84TA
Jul 15, 2016 09:05 PM
InfinityShade
Aug 22, 2015 08:00 PM
sreZ28
Aug 14, 2015 07:48 PM
mizz0313
Aug 12, 2015 06:45 AM
