Just an idea - w/in
Old Apr 8, 2001 | 04:03 PM
88'camaro305TBI's Avatar
Car: 88 IROC
Transmission: auto
Just an idea - w/in
I just recently pulled out my air conditioner, and while doing it i thought of replumbing it so that the cold air would go into the engine bay, or even better - your intake system, instead of into the car. Would that be a big enough benefit (having cold air rushing into your intake system), or would the parasitic drag of the compressor be using more power then what the car would gain from the cold air? I wonder if anyone has tried this before.
Pat Hirsz
www.iit.edu/~hirspat/MyPage2.htm
88 305TBI
Mods:Hooker Aerochamber 3" exhaust, gutted kitty, March pullies, no smog, 180 thermo,
14x4 K&N, 3.42 gears(open), Ultimate TBI Mods,AFPR,MSD(ignition,coil&wires),Edelbrock TBI Manifold, 195ltr/hr fuel pump,
Eibach springs with KYB's all around,
Harwood cowl hood, Z-28 wing, fresh paint(black)
120,000 miles, 5spd, T-tops,slp headers on its way
92 RS, 305TBI, auto, 3.08 gears, 180 thermo, glasspack (no muffler)
Old Apr 8, 2001 | 05:07 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
You guessed it, it would take more energy to cool the intake air than it you'd get from doing it.
Old Apr 8, 2001 | 05:54 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Not to mention, you can't legally run your A/C at the track. The condensation from the evaporator leaks on the track, and screws everything up, and may even endanger other racers.
If you live in Southeastern US, check us out!
South East Thirdgen
GM Master Tech
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
Whatever chip I feel like burning,
JET AFPR, Ported Plenum,
TB Coolant Bypass, Custom Cold Air,
SSM SFC, KYB Shocks, Boxed LCAs, Wonder Bar,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
gta892000
Aug 11, 2019 11:16 AM
Fox118
Sep 12, 2015 09:29 PM
Nick McCardle
Sep 10, 2015 08:36 PM
Djmathis123
Sep 8, 2015 08:42 PM
