knocking help???
Old Jun 25, 2004 | 10:14 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
Axle/Gears: 3.73 posi
knocking help???
84 z28 305
The motor runs perfect at idle with no knocking. But once you rev it up past 3 grand it will knock real bad and then stall out. It is a loud knock on the drivers side. I can then restart the car and it will run great and quiet as can be until i rev it again. The oil pressure is fine with 30lbs at idle. I also checked the oil and found no metal shavings.
Anyone have any suggestions as to what could be causing this?
Old Jun 26, 2004 | 07:43 AM
ede's Avatar
ede
get a hose, long screw driver or even a stethscope and pin point the location of the noise
Old Jun 26, 2004 | 11:21 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I like my 2' of heater hose for this purpose. Works like a charm.
Old Jun 26, 2004 | 08:07 PM
qytum's Avatar
Car: 92 Formula
Engine: 5.0L TBI
good news. Had my neighbor check it out. It turns out that a valve is sticking and the knock was coming from the piston hitting the valve. He recommended trying an additive first. So i picked up some of that cd2 valve detergent and it actually worked. I let it run for 20 minutes and kept on revving to 5 grand and have had no problems. Guess i got lucky with this one.
thanx for the replies
Old Jun 26, 2004 | 08:17 PM
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
"Good news" and "piston hitting valve" never belong in the same paragraph... IF your piston was hitting the valve you'd have lots of trouble ...nothing some junk in a bottle you buy at a store could fix.
Old Jun 26, 2004 | 08:33 PM
ede's Avatar
ede
yeah piston to valve contact = major damage
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
spartanreaper
Sep 25, 2015 07:22 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
