summit cam kits
Old Jun 27, 2004 | 09:36 PM
TheViper's Avatar
Car: '84 Z28
Transmission: th2004r
summit cam kits
i was just wondering how good the summit cam kits perform compared to other brands like comp, crane, ect. i know they aren't bad, i run the 224/234 one in a pont 455 and it runs great, i've just never ran a different one to compare it.
since i'm on a tight budget i was thinking about putting the same size cam in my 350 i'm about to build. its only temporary, the car isn't a daily driver, and i might put in a roller cam since it is an 87 block when i get the cash. i doubt this engine will ever see 10k miles.
also, how would the 224/234 do in a 350 with a 2200 stall and 3.23 gears? i'm mostly looking for the best 1/8 mile times i can get.
thanks.
Old Jun 27, 2004 | 10:43 PM
ME Leigh's Avatar
Car: 82 Z28
Engine: Al LT1 headed LG4 305
Transmission: TH350
They are fine but, old technology. The have slow ramps compared to the new better cams from comp and crane and ...
Old Jun 27, 2004 | 11:53 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
For a budget, they are fine. However, you will see more of a gain out of a Comp or Crane, Lunati or Isky. As ME said, the ramp rates on the Summit cam are slower than the 4 (and others).
If this is only a temporary fix until you get a roller cam, then sure, it will be fine. Keep in mind, you will need new pushrods and a new timing set.
Also, what heads are on the car (what valve springs, too)?
Old Jun 28, 2004 | 08:33 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
ive run 3 motors with them... they're not special, but they are working cams... ive never had a problem with any of them.
matter of fact, i had one in the motor im redoing.. when i pulled it, the cam looked brand new... and it had about 4,000 miles on it.
no abnormal wear or anything wrong.... and it always ran like a champ.
as far as i know, the other 2 motors are still running, so i assume no probs..
Old Jun 28, 2004 | 10:52 AM
nsimmons's Avatar
ive used 2 in a qjet 350 and a crossfire 350 no problems with either, probably going to get a third for this engine
Old Jun 28, 2004 | 07:45 PM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
I'd go with little milder choice from that series of cams.
214- 224@.050" .442-.465" 112LSA. #1103
or 224-224 @.050" .465-.465" 114LSA #1104
Your choice is a good one. but favours more rear gear
and a slightly higher stall converter. like a 3.73-4.10 and a 2800+ stall.
Either of the the others will have more overall torque in the rpm range you'll be using while only giving up a small amount of peak HP at the very top end. (5500rpm +) If the compression ratio is low pick the smallest one of the three. its a good one. Ran 13.0's with it in my old vortec 350. Strong torque/power from right off idle to 5000+ rpm. Use a dual plane intake manifold.
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Mickeyruder
Sep 2, 2015 02:45 PM
camaro71633
Sep 1, 2015 10:24 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
TreDeClaw
Aug 14, 2015 06:58 PM
