5 speed to 6 speed?
Old Apr 8, 2001 | 07:41 PM
Floor_it_Frank's Avatar
5 speed to 6 speed?
How involved is it to install a 6 speed transmission in place of a 5 speed on a 89 IROC with a 305?
Hello all I'm new to the forum.
Old Apr 8, 2001 | 09:07 PM
Where are all the experts?
Old Apr 9, 2001 | 02:21 AM
89ROC's Avatar
That is almost a direct bolt-in for your car.
I've swapped my car from Auto to 6-speed. Since you already have the T5, here is what all you will have to do:
-Use the T56 with the LT1 clutch, flywheel, and bellhousing.
-Use the hydraulic clutch master/slave cylinder from the LT1 car (GM part no 12559912). Just swap it out with your original one.
-Cut the shifter hole back about 2"
-get the custom crossmember from www.spohn.net It's 100bux
-make sure you have the torque arm brackets for the 6-speed.
-if you want the speedometer to work, you will have to order the custom extension housing from www.jagsthatrun.com
it's $300
Good luck!
(edit: welcome to the board )
89' Iroc-Z
ZZ3 short block-355 TPI ZZ9 cam
NOS 150 shot.
blah...blah...blah..
95' T-56, 6-speed
99' Z' rearend w/ 4.10's
1997 black Trans AM
LT1, A4, basically stock.
13.87 on the G-tech
[This message has been edited by 89ROC (edited April 09, 2001).]
Old Apr 9, 2001 | 07:41 AM
IROCketZ28's Avatar
Hey!
I've been toying with the idea of this swap, as I often go on road-trips from Tampa to Atlanta, and the thought of that 6th gear seems nice for the open interstate cruising! Is there any tranny-tunnel clearance problems to be aware of in this swap? Does a custom driveshaft have to be made (I'm not aware of the differences in external dimensions between the two trannys)? Thanks in advance guys!
'87 IROC Z28
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 800 watt stereo system
Grant wheel
Otherwise stock, & good for a 14.68 at DeSoto Dragstrip
More to come soon...
Shooting for high 13's with bolt-on's
Old Apr 9, 2001 | 02:01 PM
raging86's Avatar
the stock crossmember, tranny mount, torque arm, driveshaft, will all bolt right up, or so i've been told by about 10 people
86 IROCZ
T-Tops
700R4
305 TPI
3.23 gears
shift kit, manual TC switch, manual fan switch, flowmaster exhaust with edelbrock TES headers& hollow cat, gutted MAF.
Old Apr 9, 2001 | 09:19 PM
Thanks roc89. I mainly want to swap to gain the extra torque ability of the six speed.
Frank
Old Apr 10, 2001 | 04:52 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Did you see the tech article on how to do this?
http://www.skulte.com/T56.html
West Coast GM Shootout 2001!
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
$750 L98
Feb 1, 2025 02:25 PM
Elephantismo
Feb 13, 2019 12:51 AM
jrdturbo
Mar 31, 2016 02:58 PM
Giocio
Oct 1, 2015 12:20 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
