Motor Mount Install
Motor Mount Install
Hey, I have the L98 outta my 90 Formula, and I need new motor mounts. I know there are nuts underneath in the crossmember, and I was wondering how the hell I'm supposed to get them off? Thanks.
The big red wrench my friend.
You could undo to A-arms and let those drop outta the way, I think thats the only alternative to using a torch. Although, I have heard of guys bending box end wrenches to fit in that slot. Its a pain any way you look at it.
Have you bought the mounts yet? I have a set I'd like to get rid of. They're the ones from Auto Zone. I bought them when I did my motor swap, but the guy before me must have changed them, cause they were almost new. Becuase of the major PITA it is to change these, I just left them be, and haven't had any problems. I've never got around to returning mine, so if anyone wants em, make an offer.
Car: 1985 IROC-Z
Engine: Magnacharged LS1
Axle/Gears: Ford 9" 4:11's
Doing the mounts really isn't that hard once you figure out the right method and acquire the custom tools
I put a slight bend in a box end wrench to get to the nuts. It just takes some time monkey-ing around with it to make it work.
Car: 91 Red Sled
Only tool we needed was small hands. I don't have small hands but it would have helped. We just used a boxed end wrench and our fingertips. Yes we dropped the wrench and a couple nuts into the crossmember. Wasn't hard getting them out though. It took us about an hour to get both done.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
- Holley 670 TB unit w/ 1/2" spacer/adapter
- Edelbrock RPM vortec intake
- 350ho 330hp vortec crate motor
- 8" harm. balancer
- Stewart stage 2 water pump w/160 thermo
- SLP tri-y headers to full 3"
- Rebuilt trans w/ SLP shift kit
- Centerline 16x8's all around
- 36/24 mm sway bars
- Full poly bushings, even motor mounts
- SLP LCA and panhard
- Alston SFCs
- Edelbrock 3 point STB
- Global west steering brace aka wonderbar
- Eibach pro kit springs
- Bilstien high perf. struts and shocks
- All this and I still have AC
1992rs/ss
16
Jan 28, 2016 09:58 PM
NBrehm
Aug 5, 2015 07:57 PM
