car won't idle
Old Apr 8, 2001 | 07:13 PM
sinner's Avatar
Car: 1992 Camaro Z28
Engine: 1995 Camaro LT1
car won't idle
I have a 92 Z28. It is a 5.0 T.P.I.. It will run fine if i am moving or am pushing the accelerator. It still performs like usual. It will usually idle at 750, but is choosing to go to 500 or less. It will run at 500, but if I park it will die. It also will not start without holding the accelerator. I replaced the computor 6 months ago. (new, not used) I also replaced the fuel filter at that time. Any suggestions?
'92 Z28,t-top,PPG jet black,5.0L TPI,Auto w/stage 2 sft. kit,
Z rated tires,polished plenum/intake,flow tech 3" exhaust,PIAA driving lights
Old Apr 9, 2001 | 10:52 AM
IROCketZ28's Avatar
Sinner,
Has the car thrown any DTCs? Make sure your TPS is adjusted correctly. I was having a similar problem in that the car didn't want to run smoothly (or at all, sometimes!)below 1000 rpm. Mine was a MAF power relay (driver's side of the firewall, right next to the master cylinder), but this would throw a code "34" at you. Check for any vacuum leaks around the intake, runners, plenum, throttle body, & air ducting from air filters to the t.b.. Check that the PCV valve is functioning properly. Same for the EGR valve. Ensure that there are no leaks around your rocker covers, as this will also screw with the vacuum. Check your timing, and adjust if needed. Remember to disconnect the EST bypass plug near the passenger side firewall (near the a/c evaporator). Hope this provides some help, & let us know how things are going.
'87 IROC Z28
TPI 305
5-speed w/ Centerforce clutch
3 1/2" exhaust w/ Flowmaster
Clarion, Kenwood, Eclipse, Polk, MTX, Autotek 800 watt stereo system
Grant wheel
Otherwise stock, & good for a 14.68 at DeSoto Dragstrip
More to come soon...
Shooting for high 13's with bolt-on's
Old Apr 9, 2001 | 11:19 AM
88firebirdTBI's Avatar
replace your MAP sensor (manifold air pressure) i had the same problem. it is about forty bucks at a part store
Steve
88 Firebird TBI,TH700R4 - Open Element, Cat Delete, K&N filter 14*4 element, Dynomax Catback Exhaust, 160 Stant thermostat
1/4: 16.1@85.7 (Bone Stock)
Old Apr 10, 2001 | 11:26 PM
sinner's Avatar
It did this sunday, monday, and part of tuesday. i just left work and now it is fine. does this help you help me? i am so frustrated.
Old Apr 10, 2001 | 11:56 PM
super83Z's Avatar
Car: 1983 Z28
Engine: 6.6L 406
possible vacuum leak?
specialized
Jun 18, 2022 09:26 AM
Wade787b
Sep 29, 2015 01:15 PM
zeitghaist
Aug 18, 2015 07:33 AM
ZsTransAm
Aug 11, 2015 07:30 PM
