Can a relay cycle off and on?
Car: 83 Z-28
Engine: 406
Transmission: TH350
Axle/Gears: 3.70
I have a painless wiring kit for my Holley Blue pump and I just replaced the pump tonight. Problem is that the pump kicked off and lost all fuel pressure on the gauge. I turned the key off and turned the key on to see if the pump was running and it wasn't. I turned the key off and on again and the pump started running with 6 psi.
I don't think it's a short because it did this sitting in the garage with no vibration such as bumps and pot holes. The other pump was only giving me about 3 psi. and sounded like it was dying. Any help is appreciated.
gta892000
Sep 16, 2015 12:37 AM
