Why wont my fan come on??
Old Apr 10, 2001 | 10:27 PM
AaronRS305's Avatar
For several months, my fan has not come on automatically. I have to turn on my AC in order for it to come on and keep my engine cool. I know my fan works, but I dont know why it wont come on automatically at a certain temperature. What could it be?
1992 Camaro RS L03
Old Apr 10, 2001 | 10:41 PM
MouseCamaro305's Avatar
coolant temperature sensor, possibly thermostat
Old Apr 11, 2001 | 08:41 AM
thunderstick's Avatar
Car: '91 Z28
Engine: L98 5.7L TPI
Axle/Gears: 323's
Could be the fan switch itself or the relay. How hot do you let it get before you turn on the A/C to cool it down? Do you still have the stock fan switch? I'd replace it, if I were you...
KAM
Old Apr 11, 2001 | 10:14 AM
jobryan26's Avatar
Could also be your radiator cap not holding pressure.
'87 Trans Am:
(Engine)
305 TPI
160 Degree Thermostat
TB Bypass
Accel 300+ 8.8 Racing Wires
Accel Super Coil
Bosch Platinium Plugs
Custom Ram Air with K&N
Removed Emissions Equipment & Cat.
(Stereo)
Kenwood Excelon
Old Apr 11, 2001 | 11:09 AM
Alan84TA's Avatar
I'm going to bet its the connector to your fan switch.. Its right by the exhaust on the passenger side head. Over the years the heat makes the plastic brake and the connector can just fall off. I just noticed this on my car when I replaced the intake gaskets.
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
BrianI
Oct 3, 2015 12:57 PM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
