cooling fan problem????
Old Apr 11, 2001 | 12:12 AM
ADMZ24's Avatar
Car: 1991 Trans Am
When I sit at idle for a long time, like a stoplight or a drive thru, my cars temp skyrockets. It will sometimes stop at about 220ish. But it has been up to almost 240ish. This is cooking the engine. As soon as I take off again, it shoots right down.. right to about 180 to 190. I have a 180 thermostat, what temp should the cooling fans kick on at?? do i have a bad switch, if so, where is it??? I would think that the fans would kick on before it got to like 240..damn..thats hot..i have a fairly new water pump..NAPA replacement...stat is new too...can i get a switch to turn the fan on quicker???
Thanks in advance
1991 WS6 Trans Am
Medium Green Metallic
Beechwood interior
305 TPI
TH 700-R4, Auto
T-Tops, PW, PL, PM
Keyless entry, alarm
Flowmaster Muffler
Monza Dual Tips
K&N Filter
Old Apr 11, 2001 | 11:20 AM
Alan84TA's Avatar
Could be the fan switch or connector. I just had the same problem. Its on the back side of the passenger side head by the exhaust manifold. It gets so hot the connector just falls apart. It should be pretty obvious if its bad or not. Mine just crumbled.
Old Apr 11, 2001 | 11:41 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
if im not mistaken the fans should come on at about 220 but im not too sure since i still have the belt driven fan(soon to go for dual electrics )
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
"Wise man once say, friends dont let friends drive Fords!!"
krisner89
Oct 10, 2015 06:03 AM
Papaginos
Sep 27, 2015 03:29 PM
Ducati900ss
Sep 2, 2015 09:05 AM
JHX
Aug 29, 2015 02:30 PM
Leggman1
Aug 6, 2015 04:15 AM
