the famous hp questioin that no one can truly answer
Old Apr 11, 2001 | 11:53 AM
83CAMAROMAN's Avatar
Car: 1983 Camaro Sport Coupe
Engine: 1986 305 C.I.D. Bored .030 over
Transmission: TH350 W/Shift Kit
Axle/Gears: 3:08
hey guys the specs are in the sig just wonderin what you guys think about the set up. im planning on getting a holey 600 double pumper on it soon. i know its not a 350 but i got the motor for 100 bucks and i had no motor so i couldnt let it go.
1983 CHEVROLET CAMARO with a 1986
305 C.I.D.V8 BORED .030 OVER
HIGH VOLUME OIL PUMP
FLAT-TOP PISTONS
MILD CAM
3" CAT BACK EXHAUST W/ FLOWMASTER MUFFFLER
KEYSTONE CLASSIC WHEELS.
B&M RATCHET SHIFTER
STAGE THREE SHIFT KIT
(she'll spin em into third)
"Wise man once say, friends dont let friends drive Fords!!"
[This message has been edited by 83CAMAROMAN (edited April 11, 2001).]
Old Apr 11, 2001 | 11:57 AM
Axle/Gears: 3:08
UPDATED SIG
FLAT-TOP PISTONS
MILD CAM
EQUAL-LENGTH HEADERS
TH350 TRANNY
B&M RATCHET SHIFTER
Old Apr 11, 2001 | 11:58 AM
Axle/Gears: 3:08
WHOOPS
Old Apr 11, 2001 | 12:18 PM
burnoutrpm's Avatar
what kind of heads do you have??
89 firebird formula
356 10.5:1compression CURRENTLY DEAD!!! BEARING FAILURE!!
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
Old Apr 11, 2001 | 12:33 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
your right, nobody can answer that without some more information. whats your cam lift/duration, roller/flat tappet, heads, valve size, any portwork? what kind of intake, rocker arm ratio?
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 11, 2001 | 12:34 PM
Damon's Avatar
Flattops means decent compression- around 9.6:1 with a 30-over on the block. So that's worth something right there. Mild cam? How mild? Like stock mild or like mild for a top fuel car? Let's assume a typical flat tappet 270* grind. Heads are a big differntiator but I assume you have the stock 86 heads on there. Nothing to write home about. Exhaust is.... stock manifolds, y-pipe and cat? Ouch. That hurts.
I'll say you're around the 220-230 level. All that assumes it's tuned properly. That's my best W.A.G.
[This message has been edited by Damon (edited April 11, 2001).]
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
86IROC112
Sep 11, 2015 04:04 PM
