Distributor tuning...
Old Apr 10, 2001 | 01:55 PM
Steve89GTA's Avatar
If I turn the distributor clockwise, am I advancing the timing or retarding it?
I'm getting a little hesitation around 1200 to 1800 rpm. The cars pulls strong but only past 3000rpm. Before the distributor swap, it would pull hard from 2500. Should I turn it a little clockwise or counterclockwise...or get it timed properly with a gun...but, what do I set it to? 8*?, 6*. 6 is stock for my 89 TPI as far as I remember..it says under the hood. Also, I don't have the tab on my timing chain cover anymore ever since I changed my chain and sprockets. Will I still be able to time it with a gun if I don't have this tab?
Thanks,
89 GTA G92
305 TPI WC 5spd w/3.45
Accel Cap & 8mm Taylor's
Custom 4" Cold Air Induction
Jet Airfoil
K&N Airfilter
160 deg stat/fan switch TB Bypass - Steel Rad
Cat back 3" Exhaust w/Terminator Muff.
HiGh FlOw Dynomax Cat
Spohn LCA's - KYB GR-2's
Moroso Crank Bolt and roller pilot bearing.
Autometer Vac+Oil Temp
[This message has been edited by Steve89GTA (edited April 10, 2001).]
Old Apr 10, 2001 | 04:01 PM
Steve89GTA's Avatar
BTT
Old Apr 10, 2001 | 04:41 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
Clockwise retards.
Without the timing tab, a gun is even more useless than usual. Don't worry about it; set the timing to where it runs the best. If you have a scanner, the best way to set it, would be to advance it until the kock counts start to increase under heavy acceleration, then back it slightly off.
ICON Motorsports
Old Apr 11, 2001 | 10:00 AM
Steve89GTA's Avatar
So how much should I turn the distributor counterclockwise in order to advance it a bit. I think I may be running a little on the 'retarded' side. If I move it about an inch of travel, about how many degrees would this be?
Just to be sure, I just loosen the hold down bolt and turn the distributor unit correct? (meaning, the cam gear doesn't move at all)
Thanks for the input
[This message has been edited by Steve89GTA (edited April 11, 2001).]
Old Apr 11, 2001 | 01:52 PM
Steve89GTA's Avatar
Its a pretty simple question really...
Old Apr 11, 2001 | 02:20 PM
JakeJr's Avatar
Car: 1996 Vette / 1992 GSX1100F Suzuki
Engine: 1996 Corvette Coupe 388 LT1 (+.060)
Axle/Gears: 3.07
<font face="Verdana, Arial" size="2">Originally posted by Steve89GTA:
Its a pretty simple question really...</font>
If you move the distributor counter-clockwise an inch, you'll change the timing a ton. You only need a very small movement.
You also need to invest in a timing light; the way you're approaching this is just shooting in the dark. $35 AutoZone
Jake
1986 Corvette Coupe, 415 CID, Edelbrock 6073s, ZZ9
Old Apr 11, 2001 | 03:07 PM
Steve89GTA's Avatar
So I just turn the distributor (about a quarter inch) counter-clockwise to raise the timing. Cool, I'll try it later.
I guess when the car doesn't pull as well I can go one step back clockwise?
How do you know when it starts to knock?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
HoosierinWA
Oct 7, 2015 10:15 AM
Damon
Sep 26, 2015 04:29 PM
