Question on stock bottom end
Old Jul 4, 2004 | 04:13 PM
White91GTA's Avatar
Car: 1991 Trans AM GTA
Engine: 5.7L TPI
First off, I will be converting to the LT1 intake and using aftermarket heads and a decent sized cam. When this goes in, i will be putting a 3500 stall converter in the car.
Ok...question is, will the stock bottom end hold up to all of this additional power that will be being made?
I have had people tell me that by putting that high of a stall in, I will be breaking the bottom end and twisting the crank in half. This makes absolutely no sense to me and the guy that is doing my research on building my combo for me is a GM Certified Master Mechanic and said that the people telling me this are full of **** and don't know what they are talking about. I am just wanting to get a few more opinions from you guys, since I have found that most of you know your ****.
John
Old Jul 4, 2004 | 04:59 PM
ede's Avatar
ede
sure you might break the crank just like you might break it now. the chance of you breaking it isn't really going to increase with the changes you're making, or will only change very slightly. all in all you have nothing to worry about.
Old Jul 5, 2004 | 08:17 AM
White91GTA's Avatar
Engine: 5.7L TPI
ede...thanks for the reply. i was wanting to get a few more opinions on it, i didn't think it would cause any problems though.
Old Jul 5, 2004 | 10:23 AM
Vader's Avatar
Peak RPM, peak HP, and balance/harmonics are more likely to affect the longevity of the crank than intake and torque converter installation. However, the TC will affect peak RPM if shift points are not controlled.
Old Jul 5, 2004 | 03:13 PM
White91GTA's Avatar
Engine: 5.7L TPI
can you please explain this to me or give an idea for a place to read up on this...thank you
Old Jul 5, 2004 | 09:20 PM
Mr_Metal's Avatar
Car: '89 Camaro RS
Engine: LB8 V6 MFI
Transmission: T-5 5-speed
Axle/Gears: 3.42:1
Here's some information here that may or may not be useful:
http://www.howstuffworks.com/torque-converter-video.htm
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
theshackle
Mar 5, 2017 06:37 PM
redmaroz
Aug 16, 2015 11:40 PM
89mulletbird
Southern California Area
Aug 10, 2015 10:16 AM
Leggman1
Aug 6, 2015 04:15 AM
