line lock install
Old Apr 11, 2001 | 02:09 PM
Dee's Avatar
Dee
line lock install
Just picked up a line lock, do you tap into the front line for the front brake or is it the rear line for the front brake and does the line lock go between the master cylinder and proportioning valve or after the proportioning valve . Thanks 88' IROC
Old Apr 11, 2001 | 04:26 PM
ede's Avatar
ede
welcome to thirdgen dee. did it come with instructions? you might try looking at the makers web site. without going out and looking i think i ran a line off the rear of the propotioning valve to the selonoid and the from there to each from caliper. i had to relocate the lines to my front brakes.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 11, 2001 | 05:32 PM
Willie's Avatar
Car: 1987 Z28 Convertible
Transmission: 5-speed
I have mine spliced into the line between the MC and prop valve. The front brake is the rear of the two lines between the two. What's cool is when you engage it, the brake warning indicator will turn on because of the pressure differential between the front and back brakes -- a poor man's line lock indicator!!
However, take note that NHRA changed their rule for 2001. You can no longer install a line lock before the proportioning valve. So I will have to redo mine. I can't believe I have to do the whole thing over.
To install it after the prop valve, block either of the two front brake lines, splice the line lock into the remaining line, followed by a tee.
Willie
Supercharged 1987 305 IROC-Z, Daily-Driver, Emissions-Legal.
Paxton (6-psig): 12.57 @ 111 mph.
Paxton (6-psig) & 50-hp nitrous: 12.04 @ 114 mph.
ATI D1SC (10-psig): ?
http://willie.camaro-firebird.org/
1987 "20th Anniversary Commemorative Edition" Z28 Convertible -- Super Chevy Show Class Winner, 1998.
[This message has been edited by Willie (edited April 11, 2001).]
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Black89TA
Exterior Parts for Sale
Jul 23, 2016 10:42 AM
I'llrocya
Feb 2, 2016 11:43 PM
