400sbc heads
Old Apr 10, 2001 | 10:34 AM
scott87conv's Avatar
400sbc heads
How good are the 400sbc factory heads? Casting#333882 I want to get some performance out of the engin should i change to a edelbrock,vortec,or any other head instead of putting money into the factory heads.
Old Apr 10, 2001 | 11:27 AM
Polecat's Avatar
Get the Vortecs and have them drilled for the 400 steamholes. the 400 heads ar 76cc and a smog head at that. Not much in the performance arena IMHO.
Spend the money now and you'll have more fun later.
350 4 bolt main, Speed-O-Motive 383 stroker kit, re-sized rods ground for clearance,TRW Forged pistons,10.7:1 compression,HPC Coated RPM intake, Speed Demon 750 cfm carb,World Products Sportsman II heads,2.02/1.60 valves, Comp Cam 1.6 roller rockers, Comp Xtreme 284 cam,240/246@.050 with .540 lift,Crane pushrods,ATI damper,Proform HEI and MSD6A box,HPC coated 1 5/8 headers, 2.5" exhaust with 40 series mufflers,TH350 with Hughes 3000 stall, Powertrax NoSlip Locker, 4.11 gears.
Old Apr 10, 2001 | 03:41 PM
FAST LiFE's Avatar
They're garbage. If you're going to build a 400, then you'll need something more than the Vortec's. TFS 23*, AFR 190/5, Brodix Track 1's/-8 or Canfields.
N/A 406, TPIS Miniram, 58mm TB, 30lbs injectors, Custom Ground Elgin Cam, Ported TFS heads, SLP 1-3/4", & DFI computer.
11.70@117mph
Old Apr 10, 2001 | 03:45 PM
Where can i find info on the TFS Heads?
Old Apr 11, 2001 | 05:51 PM
camaro6spd's Avatar
fastburns would be nice...
Old Apr 11, 2001 | 06:04 PM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
http://www.trickflow.com/
http://www.trickflow.com/product/23d...r_23degree.htm
http://www.trickflow.com/product/23d...gree_specs.htm
[This message has been edited by jcb999 (edited April 11, 2001).]
Hotrodboba400
Dec 10, 2019 07:07 PM
92projectcamaro
Jan 18, 2016 08:00 AM
FormulasOnly
Sep 6, 2015 10:42 AM
z28guy134
Sep 1, 2015 11:50 PM
