quick cam question
Engine: None
Transmission: None
quick cam question
If my combo would be an l98 350, with a 750 dp, swapped to vortecs that can take up to 480 lift, and a the comp cams xe 268 cam with the lift of 480 id HAVE to go with 1.5 rockers right? 1.6 would be too much? Thanks for the replys
Car: 87 Trans Am GTA
Engine: 408 LS
Transmission: LS 4L60E
Axle/Gears: 9 Bolt/3.70 Gears/TAP Girdle
i wouldn't try running a cam that's .480 lift with springs that can only handle .480 lift... that's pushing it to the limit.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
Factory Vortec's with factory springs, i wouldn't go over .450" or so lift. But that's just me and i like to make sure my valve train is completely up to par.
Engine: None
Transmission: None
well i was lookin in summit and they have a pair of vortecs for high lift cams that have springs rated to .550 gross lift. Guess it would be safer to go with those.
Car: Z28
Engine: Sb2.2 406
Pro Topline Vortecs
They are better in many ways. Aside from being machined for more lift, they have screw in studs and, i think, guideplates as well.
