Spark Plug Wires..
Old Jul 6, 2004 | 08:07 PM
89IROCCVRT's Avatar
Car: '81 Camaro (Modded), '89 IROC cvrt (Stock), '00 GMC Jimmy
Engine: Modded 350 in '81, 305 TPI in '89 IROC, V6 Vortech in GMC
Transmission: T-350 in '81, 700-R4 in IROC
Spark Plug Wires..
I didn't know where to place this so I guess it sorta deals with this section. What spark plug wires do you all think are the best? Can I get a product number also? I've been looking all over and there are so many different sets for chevys and HEIs that I'm very confused. I just want something that i can easily remove the old wires and replace with the new, no fabricating what-so-ever. Thanks.
Old Jul 6, 2004 | 10:32 PM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
Head to your local parts store and pick up a stock replacement set for your car. You wont notice a power difference between "high performance" and stock and the stock will fit perfect.
Old Jul 6, 2004 | 10:41 PM
ljnowell's Avatar
Thats right. Seems like the best way to go to me. A lot of people waste money on things like that.
Old Jul 7, 2004 | 01:49 AM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Are you saying the stock 7mm wires are good enough for a high output coil? I thought the hot coils all needed 8mm or larger wires.
Old Jul 7, 2004 | 05:40 AM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
It doesn't hurt to spend a wee bit more and get an upgraded set of wires. I agree that it probably isn't worth going overboard with these things.
But what I would suggest is clicking on the search button. This subject has been massively done to death. Everyone has different opinions. You will very shortly get a whole lot of folks saying that you should get MSD/Taylors, and that Accells suck/no they don't etc etc etc.
I doubt that you'll see much difference between NEW stock wires, and NEW msd/taylors/accell etc but after several years use the better wire will be better than the stock ones. And if you have upgraded coils etc then this difference will become apparant all the sooner.
Si. :lala:
Old Jul 7, 2004 | 09:29 AM
ljnowell's Avatar
I usually go to the partstore and buy the lifetime warranty plugwires for every car that I own. I take them off once a year and take them to the parts store, and get a set for free. The nice part of this is that when you mess up and a header burns one, they are free.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
90formulaVortec
Sep 8, 2015 12:42 AM
89 formula TPI
Sep 7, 2015 11:06 AM
