rear end
Old Apr 11, 2001 | 07:37 PM
87firebird's Avatar
rear end
when I do a burn-out both tires spin and I was wondering if I have a posi-rear end. Do non posi-rear ends ever spin both tires or do they only do a one wheel peel??
thanks
87 firebird formula
VIN--1G2FS21H7HL212168
305 LG4
Old Apr 11, 2001 | 07:42 PM
Biochem's Avatar
Car: 2002 SOM z28
<font face="Verdana, Arial" size="2">Originally posted by 87firebird:
a one wheel peel??
</font>
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock with the exception of the Holley 750vac... all the suspension stuff... 9-bolt posi disk is in...
-=ICON Motorsports=-
Old Apr 11, 2001 | 08:07 PM
zippy's Avatar
Car: 2006 Silverado 1500
Engine: 5.3L
open diffs will occasionally spin both rear tires. need more info on the car to know if it has a posi in it. or you can check for the rpo g80.
Old Apr 11, 2001 | 10:59 PM
Blue89RS's Avatar
IF you jack the back off the ground on both sides you can tell, if you turn one tire forward and the other one turns in the same direction you have a posi..if you do this and the other one turns in the opposite direction you don't..
Old Apr 12, 2001 | 04:11 AM
ede's Avatar
ede
only way to be 100% sure is to pull the cover and look. it sounds like you have posi, if you also had the g80 rpo then i'd say you do. wouldn't hurt to pull cover to look around anyway, change the lube and add a bottle of posi additive.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 12, 2001 | 04:06 PM
87firebird's Avatar
thanks you guys that helps a lot.
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
