Manual steering box
Car: 88 Camaro
Engine: 427 BBC
Transmission: T400
85-90 S10's and some S15's. Use your pitman arm. It's an easy swap, but I did have to hammer the frame slightly to get the box to sit flush.
Miles
88 427 Camaro
12.18 @ 113mph 1.75 60ft
Currently installing 3.73's into my 9 bolt (YES,it is a 9 bolt & YES they are 3.73's, not 3.70. 4.11's to follow soon
www.koolmeister.com
Miles
88 427 Camaro
)www.koolmeister.com
only hard part for me was changing the pittman arms. i ended up using lag bolts and bolting the box to my work bench to hold the box while i got the nut off and pulled the pittman.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
You need to find a S10/S15 with a 4 cylinder to find one. 3 bolts hold them to the frame and they're a direct bolt in.
I'm lucky that I have a pitman arm puller and impact tools. I had the arms off in seconds
Follow my racing progress on Stephen's racing page
and check out the race car
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
461 Big Block installed and ready for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Altitude corrected rear wheel HP based on power to weight ratio: 476.5
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car, 91 454SS daily driver, 95 Homebuilt Harley
Best 60 foot: 1.662
1992 Trans Am
May 10, 2023 07:19 PM
backtothe80s
Sep 5, 2015 12:39 AM
