idle too high?
Old Apr 12, 2001 | 02:43 PM
v6-3.1's Avatar
idle too high?
I have a 1990 camaro RS 3.1L V6 . the car Idles at 1000 rpms, i I also get about 8mpg. the trottle body looks like its never been tampered with? could this be the cause of the terrible gas milage?
Old Apr 12, 2001 | 09:43 PM
v6-3.1's Avatar
btt
Old Apr 12, 2001 | 10:18 PM
Vader's Avatar
V6,
The idle is likely a symptom, not a cause. The idle would be high if there were a vacuum leak. However, 1,000 RPM in neutral or park on an automatic trans vehicle is not unacceptably high. Idle speed is set with the tramsnission in DRIVE and the wheels blocked. Target idle speed of 600-650 RPM in DRIVE can result in a 900-950RPM free idle speed.
The 8 MPG problem is something entirely different. You should probably check all the basic ignition and fuel system components and settings, then recheck mileage. A failing oxygen sensor can also cause an excessively rich mixture and poor fuel mileage.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
86iroczwv
Sep 3, 2015 06:21 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
IROCtometal
Sep 2, 2015 02:01 PM
