HELP with AFR stud spacing
Old Jul 8, 2004 | 07:32 PM
Anniversary-Z-man's Avatar
Car: 1992 25th Anniversary Z28
Engine: 6.3L - 383
Transmission: 700R4; Vig 3200
Does anyone know what the stud spacing is for AFR 195's? Is it standard or 40/60? I'm about to order a girdle and AFR is closed. I think it's std...but want to make sure.
Thanks,
- Joel
Old Jul 8, 2004 | 09:44 PM
Damon's Avatar
I don't think it's "standard." AFR moves just about everything around in their heads vs. a stock factory head. Subtle movement, nothing you'd see at a quick glance, but different just the same. I know their guidleplates are unique to their heads so I suspect the girdle to fit the studs might be, too. Wait till they open up and call them to be sure.
Old Jul 8, 2004 | 10:55 PM
DTL504's Avatar
Car: 84 Z28 Convertible 2 Seater
Engine: Dart Little-M SBC 400
Transmission: Pro-built Automatics 700R4
Axle/Gears: Strange Engineering 3:73
They are standard, their rocker are not offset on the AFR 195. How do I know, Look Down....
Lbibb
May 5, 2016 12:00 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
ULTM8Z
Oct 2, 2015 01:25 PM
New2Chevy
Sep 28, 2015 12:35 AM
355tpipickup
Sep 13, 2015 11:35 PM
