car is acting very strange
Subscribe
Jul 9, 2004 | 09:29 PM
here is one for you....a customer brought in a 2000 Z/28 camaro 350 5.7 liter into the shop...computer was going crazy giving serveral INCORRECT codes...customer removed his normal thermosta and replaced it with a 165 degree one...the computer in the car is used to one that is normally about 195-197 degrees, when the customer replaced to a cooler thermostat they did nothing with the computer chip...i am gussing we need to upgrade the computer chip to a Hyper tech tempature chip..or replace thermostat with normal one..customer comes to pick up car on wed july 14th what do you think is best course of action?
---J---
Reply 0
Jul 9, 2004 | 09:38 PM
What kind of incorrect codes? The power gain from a lower thermo is almost negligible, so you might as well just replace it with a normal thermo.
Reply 0
Jul 9, 2004 | 09:51 PM
Car is acting very strange?
As long as it's only an act, what's the problem?
A '00 346 V-8 likely uses an OBD-II PCM. You should be able to scan the real time data and discover the solution to the "erroneous" codes.
And good luck in finding a "chip" for that PCM.
Reply 0
Jul 9, 2004 | 11:17 PM
It's a bad act?
Swap back to the correct stat. It's pointless to change it if the fans come on at the stock settings.
Reply 0
Jul 10, 2004 | 02:46 AM
Thanks for the help guys....
Reply 0
Subscribe
