305 tpi, stumbling idle, bad mpg, down on hp help me
Old Jul 10, 2004 | 12:56 AM
jerflash's Avatar
Car: 90 Formula, 02 ws6
Engine: 305 tpi, ls1
Transmission: 700r4, t-56
Axle/Gears: stock posi 2.73, 12 bolt with 4.11s
hey guys
my 89 bird has been running bad for some time now
idle stumbles bad from about 700 to 500 feels like it has a cam haha
burns gas like crazy
and it is much slower then it should be
not throughing any codes
tested: for vacum leaks with propane and found none
changed: IAC, cap,rotor, wires, plugs, coil, distributer
adjusted: timeing, tps, iac
i was thinging maybe the MAF but not sure
i have to barrow one from a buddy to see
help me guys is there anything that i missed doing???
thanks
Old Jul 10, 2004 | 02:47 AM
89V6FBIRD's Avatar
Car: 1999 Pontiac Trans Am
Engine: LS1 - 346 ci
Leaky injectors? Put a fuel pressure gauge on the rail and turn the car to On but not Run and let the pump prime. Then turn the key to off and watch the gauge. If it drops to zero, its leaking somewhere there.
Old Jul 10, 2004 | 10:55 AM
Vader's Avatar
Have you checked/replaced the O² sensor lately?
If you had a MAF out of range, the ECM would let you know within 600mS of the error. It's pretty fast.
Old Jul 10, 2004 | 03:14 PM
jerflash's Avatar
of i forgot to add that i changed the O2 sensor
it was running so rich it was fouling plugs but that problem was solved
i know that it may not be the maf but i heard from a few placed that a bad maf does not always through codes but thats why i have not baught one yet
the fuel pressure and leaky injector idea seems like a good one
they are very old
i was thinging that the diafram in the FPR was busted
so i might get a new adjustable one and a fuel pressure gauge and clean the injestors while im in there
thanks for the input but does anyone else have any more ideas about what it could be?
thanks
Old Jul 10, 2004 | 03:19 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Check the CTS?
Old Jul 10, 2004 | 03:56 PM
jerflash's Avatar
what is the cts???
Old Jul 10, 2004 | 04:00 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
any fuel pressure readings? as far as the maf have you tried unplugging it and driving the car? If it runs better with the maf unplugged its most likely the culprate..
Old Jul 10, 2004 | 07:22 PM
jerflash's Avatar
i need to pick up a gauge
when i unplug the maf it stalls all together
does that mean anything?
Old Jul 10, 2004 | 08:34 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
coolant temperature sensor. The MAF relays are cheap PM. pull the vac line going form the FPR to the plenum and see if there is gas there. If it's running that rich, I doubt it is a pressure problem (unless you have an AFPR).
Old Jul 10, 2004 | 08:53 PM
jerflash's Avatar
i pulled the vac line from the FPR and it did smell like gas
see my problem is the only code shown when i read them is code 12 which mean the computer is ok
would a bad CTS cause it to stumble that bad and would it through a code?
and wouldnt the maf relays through codes?
i just which my car would tell me whats wrong haha
Old Jul 10, 2004 | 09:06 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
I don't, those same systems can and have been designed to tell the feds when you screw aroung with your car.
Most times they won't throw a code, but the MAF stuff has the best chance of doing so.
If the CTS is bad, it could report an abnormally low temp and the ecu would compensate by enriching the fuel mixture.
Old Jul 10, 2004 | 09:22 PM
jerflash's Avatar
i agree with you there man
im going to meet up with a friend of mine tomarrow and i will swap the maf and see if that is the problem
i hope it is so i can just go and buy a weels unit already and if its not i will pick up some maf relays and see if that changes anything
we shall see
thanks for you help guys
if anyone has any other input please say so
Old Jul 11, 2004 | 08:58 AM
Vader's Avatar
Backing up a step or two, since you set th eTPS, what was the final voltage at the closed throttle position?
Since you have a DMM to set the TPS, you should be able to test the CTS:
And you can use that same meter to analyze the MAF power and signal circuits:
Or simply measure the MAF output at a given RPM:
Old Jul 11, 2004 | 01:50 PM
jerflash's Avatar
thanks for the info, pictures, and diagrams vader
i have also thought that maybe it was the setting of the tps when closed that was causing my problems but i tried the .54 seting and alot of other and it did not make any diff in idle
inorder to read the maf output i have to put to positive term or the dvm on the signal out and the other to a ground right?
and those reading thats you showed are the normal readings at those rpms?
thanks again man this sould help alot
Old Jul 11, 2004 | 11:39 PM
jerflash's Avatar
ok i did some checking of relays and testing of sensors
maf burnoff and maf power relays are both working fine
i could not get a reading on the coolent temp because of how it is set up
it would be easier to get a pigtail and mesure it but i might get a new one anyway
so i moved on to mesuring the maf output voltage and when i inspected the wires i noticed that all the wires going to the maf except for the signal wire were at one time cut into to test for voltage and were never taped back up afterwards
a real hack mechanice worked on this car at one time it looks like so i thought i found the problem i have been looking for but it was not because all the wires wer still working fine so i taped them all up
so i moved on to testing it
it is the original unit with the screeens removed(i know thats bad but i did it 4 years ago when i did not know anybetter)
with the car at about 190 deg. 800 rpm and the filter on it read around the 0.670 area but it would bounce up to like 0.700 when it went to 900 rpm
when i would rev the car the voltage would go up in as it was pulling more air which makes sence
when i put it in drive and it was at about 600 rpm it would read the same 0.670
but when it was idling the voltage bouncing all over the place. i dont know it it is because of the idle bouning up and pulling more air or if the boucing of the voltage was the reason for the idle surging??
i spent 2 hours checking and rechecking everything and im still at a loss
so you guys think i sould start looking at the fuel system?
Old Jul 21, 2004 | 07:57 PM
jerflash's Avatar
an update to my problem
i ordered the hypertech fuel pressure gauge and the holley afpr from jegs and just got it today
i thought my fpr was bad and my injectors were leaking
so i hooked the the gauge and started the car and it read 35 then unhooked the vac line and it was at 46 lbs then hooked it back up and when i reved it it went back up to 46
then i taped it to the windsheld and started driving and got on it and it never went below 46
so i went home and tured it off to check if would bleed off fast but it stayed at 44lbs while i was looking at it but after 20 mins it went to 40 lbs
is this normal drop or no?
i will check it in an hour again
thanks
Old Jul 21, 2004 | 09:00 PM
jerflash's Avatar
ok checked it 1 hour and 15 mins after shutdown and it was at 24 lbs from the 44lbs at shutdown
what does that sound like?
thanks alot
joe
BlueIroc-Z
Jun 9, 2019 03:22 AM
drewdock87
South Central
Aug 18, 2015 09:02 PM
st.evel07
Aug 13, 2015 06:15 PM
Sanjay
Aug 12, 2015 03:41 PM
drathaar907
Aug 6, 2015 04:20 PM
