Just put in Fast Chip WITH 160 stat. Results inside
Old Apr 13, 2001 | 12:06 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
The car feels slow as hell. I mean I get on it and the car screams but doesnt seem any faster at all. It seems my stock chip was more of a bang. If it doesnt prove well at the track next week. I'm sending it back.
Old Apr 13, 2001 | 12:41 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
You're probably encountering knock retard. This is the problem with a lot of eproms. While they may add some spark, often it cause the retard to kick in and you end up loosing more effective spark than you actually gain.
Also, a common problem is they tend to add fuel. Unless you have heads/cam, you generally need LESS fuel as the GM memcal is already too rich. This is why so many SD cars actually can do a fair amount of mods on the existing eprom without needing a prom change...they are actually getting closer to the proper mixture.
Might want to consider burning your own.
Old Apr 13, 2001 | 12:49 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
should i lower my FP and retard my timing a bit?
Old Apr 13, 2001 | 02:32 PM
Car: Death Mobile
Engine: 666 c.i.
No, I would suggest getting a scan tool to find out what your engine is telling you. Without it, your just guessing. Besides, with some supportable scan tool info, Ed generally will re-do the eprom upto 3 times free of charge to get it right. Without that info, Ed (or anyone else for that matter) won't be able to make the appropriate changes.
Then you can ask him to also make it for 180* instead of 160*.
Old Apr 13, 2001 | 07:25 PM
Mkos1980's Avatar
Car: Formula
Engine: 6.0 LSX
I have a GM scan tool, the nice professional one. Anyways the 02 seemd perfect. 050-780 cruisin at 65 on the highway so it seems the fuel it ok. But what else do I check for/ Thanks
Old Apr 13, 2001 | 07:58 PM
Car: Death Mobile
Engine: 666 c.i.
Check where your BLM/INT values are. If its MAF, then you want those values for various gm/sec. If its SD, then you want them for various RPM/MAP.
Also, note the amount of knock retard you encounter. You do need a method of capturing this data as it is pretty hard to see this while you are driving.
Frozer!!!
Jan 19, 2024 04:55 PM
Fast355
Dec 2, 2016 06:33 PM
NBrehm
Aug 25, 2015 11:49 PM
NWAsonoma
Aug 18, 2015 05:45 PM
