Oil leaking from something below Oil Pressure Sendnig Unit
Old Apr 13, 2001 | 05:53 PM
sdevine's Avatar
On my 2.8, right below the oil pressure sender, theres something else there with wires coming out of it. If I pull it out a little bit, oil comes out. It seems like a plastic piece around it has broke.
What the hell is this thing?
Old Apr 14, 2001 | 06:28 AM
ede's Avatar
ede
i've never orked on a 2.8 so i don't know much about them. i'd guess your oil sender is leaking and it's getting on the thing with the wires.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 14, 2001 | 09:09 AM
Pukka's Avatar
From: Where the chicks absolutely LOVE the V-8 rumble!
Car: 92 RS - Fully Restored w/Custom Int
Engine: LO3 with some mods
Axle/Gears: 3.42 Richmond
Never worked on that engine...but the only plugs you should see would be a oil pressure sender, oil level sensor, and your drain plug. Sometimes these plugs have rubber washers on them to help give a good seal. If these washers go bad, then you would get a leak. Hope this helps.
92 Camaro RS LO3, 5-spd, T-tops
Performance:
SLP 1 3/4" Headers (Coated by Paul Barry Motorsports), Flowmaster Catback Exhaust, Fastchip Performance PROM, Centerforce Dual Friction Clutch, Xact 8mm wires, Open Air Element w/K&N Filter, Z28 Grille w/aftmkt fog lamps
Electronics:
Alpine 8030 Alarm System, Valentine One Radar Detector (How did I ever drive without one?), Pioneer DEH 7450 Head Unit w/6-pack CD changer, Pioneer DEQ 7600 Sound Processor, 2 Kenwood KAC-846 Amps powering 2 12" Pro Red subs, 2 Pioneer 6x9 and 2 MTX 4x6 speakers.
NEXT UP: TBI mods, Edelbrock performer intake
toronto formula
Nov 10, 2015 06:17 AM
Navy8125
Aug 21, 2015 09:32 AM
355sbcTPI
Aug 19, 2015 04:38 PM
drathaar907
Aug 6, 2015 04:20 PM
