Piston Rings
Old Apr 13, 2001 | 09:45 PM
DARCOM's Avatar
Car: 84z28
Engine: chevy 388
Piston Rings
this is just a senario
has any one reused rings on a motor
i am wondering if it can be done with out
ill efficts like blowby.
if it was to be done and i installed the same
rings on the same pistons and placed them in
the same bore that they were taken out of
would it work..
also these rings have only 10k miles on them
and there moly rings
Old Apr 13, 2001 | 09:56 PM
ede's Avatar
ede
as cheap as you can buy rings i wouldn't even consider it. even good rings are still fairly cheap. as for reusing rings i don't think i would. you'd have to keep the top and bottom sides figured out, as well as what groove it came out of.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
Old Apr 14, 2001 | 12:52 AM
jcb999's Avatar
Car: 89rs
Engine: 400Sb
Transmission: Tremec 3550
You could probably do it with a chrome ring but I doubt you could with a moly. Someone did ask me about my used bearings recently though wtf.
Old Apr 14, 2001 | 11:54 AM
sleeper's Avatar
You can reuse the rings if the cylinder walls are still nice and new. However it's not a good idea if you have already removed them from the piston and then reinstall them.
NZKnight
Oct 15, 2015 02:47 PM
LT1Formula
Oct 8, 2015 08:34 PM
skinny z
Oct 5, 2015 06:23 PM
gord327
Oct 3, 2015 01:25 PM
FormulasOnly
Oct 2, 2015 05:52 PM
