Help with power antenna
Old Apr 13, 2001 | 12:52 PM
1984-Firebird-SC's Avatar
Car: 2002 Grand Am GT
Engine: 3400 V6
Transmission: Automatic
It lasted me all winter just fine, then on the first nice day of spring a month back, it quit going up. The antenna motor would spin freely, but the antenna wouldn't move. I had to disconnect the motor so it wouldn't drain the battery as it kept spinning while the antenna wouldn't move. My guess is that it isn't the motor but the moving parts that make the antenna go up (gears???). Any suggestions on what I can do to fix it (or even the actual problem)???
Mike Davis 1984 Pontiac Firebird
2.8L V6 LC1
Camaro Z28 mag rims
Kenwood KDC-215 CD receiver
"Oh I've seen better days
The pain of these memories I cannot drive away" - Econoline Crush "Nowhere Now"
Old Apr 13, 2001 | 02:08 PM
RB83L69's Avatar
Car: 4
Engine: 6
Transmission: 5
That is how they usually fail. Some little gear in there strips its teeth, and that's the end of it.
You need another antenna assembly. They don't sell any of the internal parts for it. AFAIK alot of cars use the same unit so you might get lucky and catch one at the boneyard.
ICON Motorsports
Old Apr 13, 2001 | 06:47 PM
Vader's Avatar
If it helps, the location can be a little tricky to access, so here's what you're up against:
And where it is located:
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Old Apr 14, 2001 | 10:40 AM
Beefy89's Avatar
Mine did the same thing,so I turned the radio on and pulled the antenna all the way up,then disconnected the relay which is behind the trim piece below the map pocket on the dash.
Fast as a shark~~~~~~~~~~~~~~~~~ SAVE NAPSTER!!!
Old Apr 14, 2001 | 01:51 PM
nFORM91's Avatar
VADER, you're THE MAN!! You just helped me out too (with the antenna illustration)!
83 Crossfire TA
Jan 3, 2016 01:26 PM
Slush92RS
Sep 2, 2015 08:56 PM
z28guy134
Sep 1, 2015 11:50 PM
sailtexas186548
Aug 24, 2015 10:11 PM
