engine running hot
Old Jul 11, 2004 | 08:56 PM
springfield's Avatar
Car: 1992 camaro rs 25th anniversary
Engine: 305 tbi
Transmission: 700-r4
engine running hot
hey i'm new to this forum so i'm just trying to get some help, my car seems to be running hot. i let it sit in the drive way idling and it will get up to around 115, 117 then the fans will kick on and it will drop a bit but it will stick around 115, 117 all the time which is about 5-10 degree from the red which is 125.i changed the thermostat and still the same thing. i'm just wondering if there's a problem with my engine or the guage or if that's normal for the 305 tbi.
Old Jul 11, 2004 | 09:20 PM
dream02transam's Avatar
Car: 89 firebird
Engine: 2.8
Transmission: auto
Ok I assume you live in Canada and those are degrees celcius although I didnt know they coverted it on the guages for Canadian cars. Well anyways.. the weatherchannel.com has a great C-f coverter. So I looked it up. 115 = 239 degrees and 117= 242.6 degrees. I would say that is a little on the high side I dont know what thermostat you have but most cars have either a 180 or 190 -195 thermo's ( 82.22 or 87.77 - 90.55 degrees) my fan turns on about 220 -225 degrees (104.44 - 107.22) but since your fan turns on at 115 then maybe your sending unit (the one in the head with 1 wire) is reading off a little or the temp sensor (usually in the head but 2 wires) is telling the computer to turn on the fan too late. Also it is a good ides to make sure your radiator is clear in the front and back.... has a tendancey to suck leaves and bugs and other things reduceing its coolang effectiveness. Hope this helps
Old Jul 11, 2004 | 11:43 PM
robsgta's Avatar
Car: 88GTAnotchbac/91 -Z/66 Chevelle
Engine: All strokers
Transmission: Pro built 700r4's
hot
That is really hot, also make sure that none of your hoses are collapsing blocking off the flow of water the botom one should have a spring in it so it doesnt collapse..
I also had a problem with my car running hot and I almost sold it for that reason.. It turned out to be a bad thermostat after I replaced it with a brand new one it failed as well then I bought a 450 dollar aluminum radiator and it had the same problem. I removed the thermostat all together and it runs at 160 all day I am going to put another thermostat in again one day but I was just letting you know that I bought one brand new and it was bad.
another piece of advice is I bought an after market temp gauge from auto meter and it showed that my factory gauge was off by 20 degrees or more at times..
Old Jul 12, 2004 | 03:11 AM
SchwarzCamaroRS's Avatar
he has a later model LO3... those didnt have computer controlled engine thermostats... its all about the thermostat... it sounds like yours is either not working, or a little broken... its on the passenger side of your engine on the cylender head... just do a for "fan switch" or "overheat problem" and you will be bound to be led somewhere that has already addressed this issue
Vintageracer
Jan 10, 2020 05:33 PM
theshackle
Mar 5, 2017 06:37 PM
Jae992
Aug 27, 2015 09:07 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
camaroken83
Aug 10, 2015 11:35 AM
