hard start on new motor??
Car: 89 Formula
Engine: Carbed 5.7
Transmission: TKO-600
Hey guys I just helped my buddy put the GM 330 horse crate in his truck, he has a performer intake on it and a 670 street avenger, now when he goes to start the damn thing the starter almost can;t turn the motor then finally it will roll over and start, Now we have messed with his timing from 8 degrees to 12 degrees with no change, Hes got long tubes on the truck but its a brand new starter and it has a brand new heat sheild wraped around it, Is there anythign else that can cause this cause I'm lost. thanks
Car: '82 Z28
Engine: 350HO
Transmission: M4
do what ede said.
also verify that your TDC mark is accurate. because timing that is too far advanced will cause that problem.
if all else fails, buy a stronger starter.
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
You say "new" starter? But what is the actual starter? Is it a high-torque with gear reduction? Or is it a factory reman'd one?
Car: 89 Formula
Engine: Carbed 5.7
its a stock reman for an 89 firebird with a 305, the same one I have on my car and i have more compression and alot more cam and mine cranks liek a stock car.. I dunno what is going on, it seems the timing isn;t doing anything..
theshackle
Mar 5, 2017 06:37 PM
92camaroJoe
Aug 13, 2015 06:07 AM
