esc problem, suggestions are appreciated
Old Jul 13, 2004 | 01:24 AM
thatoneguy's Avatar
well i have a, for the most part, stock 91 r.s. 305. i just put a new engine in, and felt good about have a reliable car again. well i was driving and it just lost about 75% of its power and set a code, read the code and its the esc. any suggestions of what specifically this could be? i have replaced the igintion module 3 times now and would doubt that thats what it is once again. any ideas???
Old Jul 13, 2004 | 04:06 AM
ede's Avatar
ede
trouble shoot the ESC circuit and parts
Old Jul 13, 2004 | 09:01 AM
dankhound's Avatar
Car: 91 RS
Engine: 305 Tbi (L03)
You may still have a problem with the ignition module. Have you been using the dielectric grease when you install them? You may also have a wire that is intermitantly shorting and taking out the module.
Old Jul 14, 2004 | 12:59 AM
thatoneguy's Avatar
yeah i use the grease every time i replace it, and i have also replaced about two feet of the wiring as well as the connectors leading to the ignition module. once it sets a code, i turn the car off, then start it again and it will run fine until the first time i get on it even the slightest little bit, then it sets a code again.
Old Jul 14, 2004 | 01:01 PM
bnkrptlsr's Avatar
bump
Old Jul 14, 2004 | 01:42 PM
Trickster's Avatar
Car: 1989 Iroc-Z
Engine: 5.7L TPI
Here is something that you can check out, it is mentioned in the service manual. A code 42 can be set by the EST wire harness being routed too close to the sparkplug wires.
Infested
May 22, 2018 11:56 PM
backtothe80s
Sep 5, 2015 12:39 AM
beast94
Aug 20, 2015 06:44 AM
Bradsaundry
Aug 12, 2015 12:34 AM
