Edelbrock additions to the 305. Is it worth it?
Old Apr 15, 2001 | 11:06 AM
82Zee28's Avatar
My 305 is pretty stock. No mods that I am aware of. I've got an Edelbrock RPM manifold and cam (and valve springs). As well as the Edelbrock 750 cfm carb. I am considering putting these in and trashing the Quadra jet carb.
My question is, has anyone done this to their 305 and what kind of performance enhancement did you notice? It's not low end torque but I am hoping I get enough positive feedback about this to actually do it. If it's not worth it, then I'll just hold on to the parts til I get an engine (350) worthy of these mods.
Old Apr 15, 2001 | 01:15 PM
Chvywolf's Avatar
Car: Formula
Engine: Pontiac 400
Axle/Gears: 4.10
I swapped my L03 TBI over to carb with the RPM intake. All mods are in the sig. To be honest though, that 750 seems a bit much for that little engine. With the setup i have now, i had to put smaller jets in the Holley just to not run as rich all the time. Only way i can see running a 750 in it is with a BIG cam. Don't know if this will do you any good but it's my .02 cents.Laters
"Oh yeah, well i'm taller"
89 RS Conv 305 700R4
85HO heads
Edelbrock intake
Holley 600
Hedman Hedders and Y pipe
Flowmaster
B&M MegaShifter
Old Apr 15, 2001 | 06:55 PM
84TransAm's Avatar
600 CFM is all you need for a 305. Even though I used a Holley carb, there is a noticeable torque increase over the stock quadrajet. Adding the Carb and manifold will definently yield a noticeable power increase.
However, your higher speed (60 mph+) will probably choke since you most likely have stock exhaust manifolds.
--Steve S--
1984 Trans Am 305 LG4, 5 speed Daily Driver, Flowmaster 80 Series
Holley 600 cfm & vacuum advance Soon: Edlebrock Intake & TES
Old Apr 15, 2001 | 08:39 PM
jbenge's Avatar
Car: 1991 Camaro Z28
Axle/Gears: Strange 12 Bolt, 3.42
I've swapped in Edelbrock carbs and intakes on 2 different thirdgens, its definately worth the effort. Makes enough difference that you can feel. I also agree that you should go with a 600cfm carb on your 305. Also consider getting headers and upgrade the exhaust to get the most out of your parts combination.
best 1/4 mile so far: 13.4 @ 101mph
84 Camaro 305 ported & milled heads, 3 angle valve job, Edelbrock Performer RPM intake, Hedman full length headers, Accell ignition, Crane 274H cam, B&M 700R-4, 3000 stall speed, 4.10 gear,
M/T ET street tires
visit my website at http://www.geocities.com/jbenge/page1.html
sreZ28
Oct 22, 2015 08:21 AM
Dwayne614
Sep 29, 2015 11:05 PM
dennisbernal91z
Wheels and Tires
Sep 12, 2015 12:28 AM
toronto formula
Sep 10, 2015 07:31 AM
DARKmj16
Sep 9, 2015 04:07 PM
