Rough idle, dies.
Old Jul 13, 2004 | 04:46 PM
my69camaro1's Avatar
Car: 1969 Camaro/2000 F-250/85 IROC
Engine: 383 Stroker/V10/305TPI
Transmission: Turbo 350/?/700R4
Rough idle, dies.
Just got an 87 350tpi IROC. Sometimes while driving through town, when I stop at a red light it starts to jump up and down from 1,000rpm+- to 400rpm+- and unless I get on the gas it will die. It normally idles at 600+ just fine. It runs at less than 220 F* most of the time but in heavy traffic it will go just above.
Only does this once in a while, not everyday.
Old Jul 13, 2004 | 05:40 PM
DJXero's Avatar
Car: 1992 Camaro Z28
Check your IAC (there's an article on it in the tech articles section on the site), also, check your fuel pressure, just in case. An injector may be leaking or your fuel pressure regulator may have small tears in it (your same symptoms happened to me, and it got alot worse very quickly)
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
IROCtometal
Sep 20, 2015 11:08 PM
IROCtometal
Sep 9, 2015 10:01 AM
89fast5oh
Sep 8, 2015 09:55 AM
IROCtometal
Sep 2, 2015 02:01 PM
