Does the knock sensor go into the heads or the block?
I'm putting a pre-86 engine into an '88. I've got a hole predrilled into my Sportman II heads for a sensor - but it's much larger than the threads of my knock sensor. Do I need an adapter for my knock sensor to make it fit there? OR - There is a hole fitted with a pipe plug in the actual block down by where the oil pan mates with the block - that one looks to be the exact size that the knock sensor fits - can I put it there?
Just need some advice here...
Thanks,
Steve
Thanks,
Steve
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
The knock sensor belongs at the bottom by the oil pan (Block drain). THe hole you're talking about sounds like it's for either the temp. sender for the gauge (drivers side), or the secondary fan switch on the other side!
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Working on:
145 MPH IROC Speedo
9192camaro
16
Feb 3, 2019 12:21 AM
