Pulling Engine and Trans
Old Jul 13, 2004 | 07:21 PM
John V's Avatar
Car: 89 IROC, Convertable
Transmission: Automatic
I bought a 89 IROC convertable and the transmission died. Because it is my third car and I dont need it as my daily driver I decided to pull the engine and trans at the same time and fix all the little leaks. I am having the transmission rebuilt with some high performance parts, but I am running out of money. is it worth redoing the heads without rebuilding the engine, should I just replace the oil pump and water pump and call it good, or is there somthing I am missing.
Old Jul 14, 2004 | 10:34 AM
SinthetikIroc's Avatar
Car: Corvette
Engine: 5.7
does ir run fine? is it a 305 or 350? if your gonna have the heads worked over then you should put a cam in as well.
84z96L31vortec
Aug 20, 2017 12:16 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Sanjay
Aug 12, 2015 03:41 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
Exxon Limited
Aug 9, 2015 08:13 PM
