Stupid, but quick sensor/switch question>>
Old Apr 14, 2001 | 06:30 PM
Jester's Avatar
What are the 2 sensors/switches in the top of the brakes proportioning valve, and in the power steering lines? I just wanna know if I can ditch them and the wires leading to them, I have NO ECM or anything. Thanks.
"American made baby. 100% American iron. The muscle among the masses. My hero. Yep, you can take your ergonomically designed, space age, computer controlled, 4 door, cup holding map lighted split double wishbone split fold down retractable cargo covered moon roof piece of transportation and keep it. For I have felt the thunder. And I know the difference!"
JSP Motorsports
ICON Motorsports
Old Apr 14, 2001 | 07:00 PM
eightTfourTA's Avatar
Car: 84 T/A
Engine: 305HOL69
In the top of the brake's prop. valve, that's the sensor that turns on the 'BRAKE' light in the dash for when your brake fluid gets too low. Not sure about the second one...
The one in the power steering line, I believe, is for the air cond. cut-out under heavy pump load.
DR Stevens
1984 Trans Am 305HO L69
sucks gas, hauls ***
1991 Firebird 305 LO3
for days when I need a/c
Old Apr 14, 2001 | 07:14 PM
Jester's Avatar
I was thinking it was something liek that...so I could cut the wires out of my engine bay Thanks man.
I just wanted to be sure.
Old Apr 15, 2001 | 09:22 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'd say leave the brake wires for safety reasons (the ECM doesn't use these lights, they operate the warning light), and ditch the P/S ones (They are for the ECM, or the A/C system, not sure which without looking it up)
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Old Apr 16, 2001 | 12:07 AM
Car: 84 T/A
Engine: 305HOL69
Yeah, I agree with JP, leave the one on the brake's valves so that just incase you have a brake failure, you'll be warned about it. I'm glad they put that there, it saved my sorry *** on one of my old NY beater cars in which the lines rusted thru and I lost ALL my brakes, had to slam down thru the gears and stand on the e-brake to get it stopped.
(long story)
DR Stevens
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
happyhapka
Aug 15, 2015 04:42 PM
gta power
Aug 13, 2015 06:15 AM
