What oil&weight are you guys running?
Car: 1988 Pontiac Trans Am
Hey 85ZZ4TPI I use reg. Mobil 5w30. When i get 4000 miles on my new motor i will change to Mobil 1 Synthetic.
- 1987 T/A 350tpi, 5speed, Stock exhaust, Gutted Cat,Compucam 2030 429 452 & 204 214,TbBypass,Ported Plenum,AFPR. 14.37@93.4mph 1.99 60ft
85ZZ4TPI check out F-Body.Org. I got the instructions from there. I believe i'ts under FAQ.
Car: 94 Z28
Engine: LT1 w/ headers, catback, CAI, tune
Axle/Gears: 3.23s
I run 10w30 in mine. Oh yeah and in case you missed the recent posts, don't use a Fram oil filter. Using the AC Delco filter is the common recommendion, I'm running the Bosch w/ good luck.
Ray87Z
-Vortec headed 350.
86 IROC w/ a cammed 305 TPI.
Formerly Ray86IROC.
www.inter-scape.com/Ray
Ray87Z
-Vortec headed 350.
Formerly Ray86IROC.
Transmission: 4L80E/4L80E
AMSOIL 10W30 synthetic in the Camaro, 0W30 synthetic in the 396. AMSOIL filters on both (best filter out there).
Show that new powerplant some respect and use the best. Anyone who uses petroleum based oil in a healthy engine has no respect for their machinery. Using a "me-too" synthetic isn't much better (Valvoline, Penzoil, Castrol, etc.).
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 3.08 open, cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress.
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Mobil One 10w30. 120k miles, never apart (so I've been told). Needs valve seals. Amsoil, Redline, and Royal Purple (Maxoil) are the best, but expensive. Too high for my old beater (until the stroker comes, anyway).
New (to me) 87 Formula 350. Edelbrock TES, Flowmaster, airfoil, K&N in modified airbox, March underdrive pullies, still slow....for now.
Car: 95 Caprice
Engine: 5.7l LT1
Axle/Gears: 2.93
this might sound a bit heavy, but my oil pump aint quite the best.. so in the summer i run 15w40, and 10w30 in the winter.. i always use a wix or delco filter..
mobile 1 15w-50 what else,they only recommend 5w-30 for gas milage,and i hate oils that drain out of the pan like water how good could they be?
1990 Trans Am,350 TPI(L98),WS6suspension ,bridgestone RE71's /245/45/zr16
paxton supercharger, alston sfc's,msd 6AL-BTM,
8.5 superconductor wires SLP 1-3/4 headers,duel cats,3"slp exaust, lakewood LCA's,T.B.Bypass
160 degree stat,alum driveshaft,fiberglass wing, secret mods
"if you cant win fair CHEAT"
Car: 89 IROC
Engine: 350 HSR
Transmission: modified 700R4
Mobil 1 5w30,filter AC/DELCO I learned my lesson at the track last Fri.Spent rest of Fri. night and all of Sat. rebuilding motor.
86 IROC mods:T.E.S.,Flowmaster muffler
T.P.I.S. airfoil,ported plenum,March
pulleys,Accel 8.8wires,supercoil,ign.mod.
RAM AIR induction,gutted MAF,
B&M shift kit,3.73 rear gears,Accel afpr,Hypertech stage 2 chip,Random Tech.cat.,Lakewood lower control arms,Lakewood adj.panhard rod
"The more I learn about women,the more
time & money I spend on my IROC"
I am running Valvoline Durablend 20w50.
1987 Iroc
'93 Corvette LT1 350 engine
350 Turbo trans
4" inch Cowl Hood
Adjustable Nitrous Setup(75-175 Hp)
Modified Air Intake
T-tops
Selling an '85 Sport Coupe
email for details stalemate@pcc.net
1987 Iroc
350 Turbo trans
4" inch Cowl Hood
Modified Air Intake
T-tops
Always Quaker State. In this heat I run straight 30. In spring and fall I run 10W30.
1982 Z28 Pace Car
383 Small Block 4 bolt
Performer RPM manifold, Holley 750 vac sec, Crane cam, 2.02 heads
TH400 trans (TCI Parts)
7.5 10 bolt rear w/3.73 Posi
Shorty headers, True dual exaust
Custom 4 core rad
Autometer tach and guages
Ultra rims w/BFG Drag Radials
13.60 @99 Mph
http://www.82pacecar.homestead.com/files/index.html
1982 Z28 Pace Car
Custom 4 core rad
13.60 @99 Mph
Remember, oil film thickness between the ring face & the cylinder bore is influenced by oil viscosity. The lower the viscosity, the less oil film thickness which translates to higher ring face & bore wear over time. I would recommend 10W30 as absoulte minimum, with 10W40 being prefered for hot weather driving, especially if engine is pushed "hard".
FJK
FJK
I run Mobile 1 synthetic 15W-40 in the 3 hot summer months, and 10W-40 the rest of the time. I do use Amsoil from time to time when money...and the wife allows!
1984 L69 Z28 with 350 H.O., Hypertech ThermoMaster Chip w/ 160* PowerStat, Stock L69 Dual Air Intake w/ K&N, L69 Dual Plane Intake Manifold, Modified Q-Jet, 350 4 bolt main w/ Crane Energizer Cam & 1.5 Roller Rockers, Lunati Drop Forged Crank and Rods, 23 Degree Trick Flow Heads, Hooker Comp Headers, 3:73 Posi, T-5 (Soon to be a T56!), 4-wheel disc brakes, 3" Catback Exhaust...etc.
Wise man say....Man who jump on bedspring this spring....have offspring next spring!
Mobil One 5w30 with an AC filter. What weight is recomended? I have been wondering if this is too thin for an L98? It holds good oil pressure.
87 Formula 350 14.81@91.64
98 Z28 1LE 13.15@107.59
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Valvoline 10W40 (I like how clear it is) and AC PF35 oil filter. When I put the new engine in, I will be running Mobil 1 synthetic, but not sure about the weight.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Working on:
145 MPH IROC Speedo
i use pennzoil 5-30, pennzoil 10-30, mobil1 10-30. mobil 1 15-50, seems i run a differant oil in each engine. all ac or wix filters.
ICON Motorsports
1st & 3rd
MM Black Diamond 538 F&AM
ICON Motorsports
1st & 3rd
Car: 82 camaro SC
Use a good quality oil and filter and CHANGE it EVERY 3000 miles. The best oil in the world won't protect your engine if the oil is worn out or dirty.
82 camaro--original steering wheel, brake/gas pedals, seats--everything else modified
82camaro
82camaro
15W50 Mobil 1 and AC PF25 on the 'F' car. I only use the car in the summer. The daily drivers get 10W30 Mobil 1 and the appropriate AC oil filter every 3,000 miles in colder weather (down to -35°F) and 15W50 in the summer.
I wouldn't use anything with much lower viscosity than 10W (ISO 46), especially in a synthetic. The pour point is more than low enough for anything I'll ever encouter, and teh high temperature protection is much better than mineral oils.
I had 10W30 Mobil 1 in the case last year when the temp hit -37°F with my wife's Astro parked outside the cabin, in the wind. The battery was definitely a little "less fresh" in the morning when I started it, but it cranked and fired with no problems and no detectable noise from lack of lubrication. I think I would have been a screwed puppy with 5W30 mineral oil, for sure. Besides, I like my engines too much to use 5W-anything at highway speeds and loads. One set of bearings for every 300,000 miles is plenty for me.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Later,
Vader
"What a Day..."
Castrol 10w30 in the f-body, and my dad's 2000 Galant.. Castrol 5w20(isn't that ****ing scary!) in the Civic.. even worse.. Ford uses 5w20 in freakin 5.4L triton V8's.. in Expeditions and whatnot.. want to void your warranty.. go ahead and use something else.. That just scares me.
when the time comes to put a new motor in the RS I'll break her in with either Castrol or Valvoline.. and it's Mobil 1 or Royal Purple from then on.
Anthony
previous ride: 87 Camaro LT
350, A4.Comp Cams 268H, Edelbrock Preformer intake, Hedman Headers and y-pipe, gutted cat, No AIR/smog pump. 14x3" Open element K&N, Q-jet w/ D hanger and DA rods, adjusted AV spring tension and quick can.
Current ride: 1992 Camaro RS, K&N, Flowmaster, 305, T5, Black, T-tops, 74k miles.
Anthony
Car: 89 IROC
Engine: Yes
Transmission: That, too.
<font face="Verdana, Arial" size="2">Originally posted by camaro6spd:
What is the matter with FRAM? My dad and I have used them in all our cars with out flaw.</font>
http://members.nbci.com/minimopar/oilfilterstudy.html
I personally use Valvoline 20W-50, with AC filters for the IROC. Valvoline 10W-40 for the pickup.
86IROC112
Aug 17, 2015 02:00 PM
