?on how to put the distributor
Old Jul 15, 2004 | 06:40 PM
miacamaro305's Avatar
Car: 89 Camaro RS
Engine: 5.0 tbi
Transmission: street-strip 700R4
okay guys i just rebuild my motor and now i dont know the right way to drop in the dist. back in. wat do i do and i know that the rotor has to point to # 1 but wat side the bronze contact or the back part facing # 1????????
Old Jul 15, 2004 | 06:43 PM
Ramair21's Avatar
Car: Camaro RS/SS
Engine: 5.7 LS1
Transmission: 4L60E Transgo shift kit, 3500 stall
Axle/Gears: 4th Gen Rear 3:42
hey bro, your almost done huh? the bronze contact has to face 1. good luck man, and you have to time it again after that well as soon as you turn the engine on
Old Jul 15, 2004 | 08:20 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
okay i know one part now but how do i know in wat place the engine has to be to drop it in isnt at tdc with #1 piston all the way to the top?
Old Jul 15, 2004 | 08:30 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
To easily reinstall the distributor, it really does help to have the #1 piston at TDC of the compression stroke, otherwise, it is sort of a hit and miss ordeal.
To find TDC compression, remove the #1 spark plug and put your finger over the hole. Make sure you remove the 12v power wire to the distributor first!!. Once you feel pressure building behind your finger, remove it and bring the engine to TDC. I like to rotate it via the crankshaft. A strap wrench around the balancer pullel works well for this. Once you have TDC compression drop the distributor in. It doesn't really matter which terminal on the distributor is #1 so note which terminal the rotor is pointing to and make that #1. From there, follow the SBC firing order around. Tighten the dizzy clamp bolt just enough to hold it in place, but keep it loose enough so you can rotate it by hand.
Old Jul 16, 2004 | 06:52 PM
Car: 89 Camaro RS
Engine: 5.0 tbi
well thanks i already found did and all work out fine so i was able to start it up today it sounds more aggresive with the lt1 cam
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
g.l.mos
Aug 22, 2015 12:02 AM
86IROC112
Aug 17, 2015 07:57 PM
cstrobel65
Aug 15, 2015 10:19 AM
