Arg... Oil pan WOES! It came out but WTC!
Old Jul 15, 2004 | 12:33 AM
Kingtal0n's Avatar
Car: 5.3L turbo 2800lbs RWD
Transmission: 4l80e
Axle/Gears: 3.512
what the crap. I use an engine lift to pull the motor up high enough to remove the oil pan. I braze my fitting into it for the oil return lines, then walaa...
IT WONT GO BACK IN!
Im ABOUT to drop the tranny off completelly, Ive spent HOURS trying to line the motor high enough and far enough back to clear the K-member.
I just want to know any tips/tricks before I go ripping out the tranny just to replace the oil pan. Im thinking maybe if i just jacked it up from the flywheel instead of pulling the motor up/forward with the lift. suggestionsS???
Old Jul 15, 2004 | 12:50 AM
DuronClocker's Avatar
Car: 1997 Corvette
Axle/Gears: 2.73 IRS
Jacking it up by the flywheel does NOT sound like a very good idea to me..
Old Jul 15, 2004 | 01:10 AM
taonindo's Avatar
Car: 82 firebird
Engine: 406
are you sure the fittings are not hitting somthing ie. webbing or a main cap ... use a mirror to see what the hang up is ... good luck ... tao
Old Jul 16, 2004 | 08:23 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Does the pan have any baffles in it? Is the pump pickup maybe hitting it?
Old Jul 16, 2004 | 08:27 PM
Kingtal0n's Avatar
Transmission: 4l80e
Axle/Gears: 3.512
I hate this thing. I messed with it for 4 hours today, and NOTHING. Im going to have to pull the trans away from the motor.
It hits the K-member, or the flex plate. if I lift the motor high enough to clear the flex-plate, the motor moves far enough forward that the sump in the oil pan hits the K-member. if i drop the motor low enough to clear the K-member, it is no longer high enough to clear the flex plate.
WHAT A PAIN!!!
BDR
Nov 7, 2015 03:05 PM
project89
Sep 22, 2015 09:35 PM
abray1
Sep 14, 2015 08:18 AM
timonator
Sep 13, 2015 11:49 AM
dmtz956
LSX and LTX Parts
Sep 6, 2015 04:45 PM
