friends camaro running like Sh*t
Old Jul 16, 2004 | 06:15 PM
87z28camaro's Avatar
Car: 1987 Z28 Camaro
Engine: 305 tpi
my friend has either a 85-86 (forgot) camaro, it is the v6, ok he started having these problems about 2 weeks ago, it would miss and sound crazy, it did not smoke or anything, thought it was distributor, and it was not that, replaced all spark plugs and wires, all looked fine, but replaced anyways, still ran the same, then we done a compression test, and only 3 cylinders on one side have compression, btw the car does not smoke a bit, oil looks good, still starts every time, very confused, time for rebuild ? or is it something simple???/ sorry this is so long, we just are stomped on this one, thanks
Old Jul 16, 2004 | 06:34 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
only 3 of the 6 have compression?
Old Jul 17, 2004 | 05:13 PM
Engine: 305 tpi
yes only 3
Old Jul 17, 2004 | 06:41 PM
ljnowell's Avatar
Zero Compression = Shot
Old Jul 17, 2004 | 08:47 PM
Air_Adam's Avatar
Agreed... or at the very least, a wiped cam. (no intake lobes, nothing comes in to make compression)
Old Jul 17, 2004 | 11:33 PM
92rs85berlintta's Avatar
Car: White 25th Anniversary RS
Engine: lt1
Transmission: t56
Axle/Gears: 4:10
seems kinda weird only one side had compression. also seems like its against the odds for one side of the cam to wear and not the other since they are all different lobes. has anyone messed with the rockers? or the head?
seems like it wouldnt run off 3 cylinders as well cosidering the gap in the firing.
are you sure theres zero compression?
time for rebuild ?
it is the v6
or time for a 350
Old Jul 25, 2004 | 08:39 PM
Engine: 305 tpi
yes, it does start everytime, and blows completely no smoke, i took it to a mechanics house and he done the compression test, and then he said no compression on 3 cylinders on one side, then he made an offer on how much he'd buy the vehicle from my buddy for, soo that sounded fishy to me
Vintageracer
Jan 10, 2020 05:33 PM
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
Reborn756
Sep 4, 2015 03:42 AM
Linson
Aug 21, 2015 02:12 PM
squiggy2
Aug 9, 2015 09:30 PM
