vacuum leak
Old Apr 17, 2001 | 01:36 PM
88transam5.0's Avatar
vacuum leak
Whats the best way to check for a vacuum leak do I use some kind of solution. I,ve replaced most of my vacuum hoses. now how do you check intake man. I,ve use a vacuum guage and before I had engine rebuild my vacuum was about 21 and steady and now my vacuum is about 20 - 20.5 but not steady ( needle moves back/forth slowly. I hooked up the guage to the plenum along side the fuel reg. port. is this the best place? thanks.
Old Apr 17, 2001 | 02:21 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
if you have 20-20.5 "hg vacuum i doubt if its leaking. normally a vacuum leak will put you down around 15 or less.
good way to find a leak is with propane or carb cleaner, (i prefer propane).
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
FormulasOnly
Jul 23, 2018 08:47 AM
bbsr72
Apr 2, 2016 09:12 AM
jrdturbo
Mar 31, 2016 02:58 PM
86maro_252
Oct 10, 2015 06:52 PM
ndndndnd
Carburetors
Sep 16, 2015 04:13 PM
