1.6 rockers
Old Jul 17, 2004 | 09:47 AM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Transmission: 700 r4
1.6 rockers
How much small horsepower and torque would be added to a lg4 engine? Probally not enough to warrant the expense.
Old Jul 17, 2004 | 11:13 AM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
Transmission: Jerico 4 speed
Axle/Gears: Ford 9" 3.60
I think you'd be suprised.
Old Jul 17, 2004 | 05:02 PM
The Chad's Avatar
Car: 84 berlinetta
Engine: lg4
Any one else care to estimate. I don't really understand the formula, lobe lift x 1.6. The lg4 cam specs is 178-194 0.350-0.385-109 seperation. I think by research 4 degree increase in camshaft duration with 1.6 rockers.
Old Jul 17, 2004 | 05:20 PM
Stekman's Avatar
Car: Z28
Engine: Sb2.2 406
The lift is what you say. Divide the lift by 1.5, then multiply by 1.6 to get the new lift.
As for the duration, the duration ITSELF doesn;t change but the .050" will see an increase of about 3-4 degrees. Depending on what rockers you go with, it is worth it. I put the Comp Magnums on my LG4 that i have. I'm not going to say whether or not I feel a difference, but it's a cheap way to get a bit more lift and a inkling more duration (@.050") without actually changing the cam.
I would say go for it. Remember, they are a crossover part, meaning that they are not specific to either the 305 or 350. SO if you swap heads or anything, you can swap the rocker arms over.
Old Jul 17, 2004 | 09:23 PM
25THRSS's Avatar
.373/.410 lift with 1.6 rockers
Old Jul 17, 2004 | 09:46 PM
pasky's Avatar
Car: 1991 RS Camaro (Jet Black)
Engine: 95 383 CI (6.3) LT1
Transmission: 95 T-56
roughly 13rwhp.
Old Jul 17, 2004 | 09:49 PM
25THRSS's Avatar
more if you go full roller
Old Jul 18, 2004 | 01:51 AM
Streetiron85's Avatar
Car: '85 IROC
Engine: LB9
Transmission: 700 R4
I switched to a set of 1.5 rollers rockers and there was a noticable increase in power and throttle response.
After all the major mods have been done, like headers, cam, and a good set of heads. Then it's good to begin working on mods like roller rockers that don't nessecarily offer as great a HP/$ increase, but they do help out none the less.
Roller rockers get the from me
Old Nov 10, 2004 | 11:25 AM
Zrated83's Avatar
Car: 83 Z-28
Engine: LG4
Axle/Gears: 02 WS6 Rear w/3:42
Originally posted by pasky
roughly 13rwhp.
From just upgrading to 1.6 rockers, wow. Looks like I may have a new mod to do Chad did you do the upgrade yet?
Old Nov 10, 2004 | 11:54 AM
pasky's Avatar
Yep, Stock LT1 guys have gained around 13 rwhp. This was dyno proven.
Old Nov 10, 2004 | 01:09 PM
Zed'er's Avatar
Car: 84 Z28HO
Engine: 350 summit block
Axle/Gears: 3.73 10bolt
Can you still use standard pushrods with the 1.6's or do you need shorter/longer ones?
Old Nov 10, 2004 | 01:11 PM
bluegrassz's Avatar
Car: Camaro
Engine: Carbed L98
Transmission: TH350
And do you have to slot the pushrod holes in the heads using 1.6?
Old Nov 10, 2004 | 01:29 PM
25THRSS's Avatar
You can use the same pushrods, and most of the time you will not have to do anything to the heads.
Old Nov 13, 2004 | 04:14 PM
blacksheep-1's Avatar
Car: 83 Z28
Engine: vortec 305 for now
Transmission: 5 speed
But check to make sure, I have installed 1.6 rockers on my L69 and I'm going to have to open up the guideslots in the head.
Old Nov 13, 2004 | 04:22 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
The increase in power isn't so much from the ratio increase of .1, its because a set like those will be alot stronger than the GM ones, so they won't bend like the GM ones. GM says theirs are 1.5 ratio, but because of the amount of flex in them, its usually alot lower, like 1.2 or so. Sometimes even less, depending on the cam.
Old Nov 13, 2004 | 05:19 PM
Car: 83 Z28
I don't know, depending on the valve springs you're probably right, but If your running fairly mild springs I don't think it'll be a problem.
Old Nov 13, 2004 | 06:51 PM
Air_Adam's Avatar
You'd be surprised.
UltRoadWarrior9
Apr 28, 2020 10:39 PM
slowsi
Oct 18, 2015 08:49 PM
Jorlain
Oct 8, 2015 01:57 AM
tcarlos13
Interior Parts Wanted
Sep 28, 2015 06:31 PM
TX-SleeperC5
Sep 24, 2015 03:13 PM
