What does the egr do and why is it so important.
Old Apr 17, 2001 | 01:14 AM
Stormshadow GTA's Avatar
and if i remove the egr walls behind the throttle body will that mess the egr up .or will it just free up a lot of airflow for me
Old Apr 17, 2001 | 05:23 AM
JPrevost's Avatar
Car: 91 Red Sled
http://www.misterfixit.com/egrvalve.htm
Keep it there unless you want problems. If you don't watch it and you disable EGR you could run into problems like knock. When that happens your timing will be turned down low and you'll loose lots of power and have no throttle responce. The right way to get rid of EGR is to reprogram the chip for less advance and a few other little stuff. Don't just unplug.
, Jon (350 TBI! getting 23mpg highway)
91 Red RS w/grey int, sq stereo (Alpine v12, kicker solo, MB quart premium etc)AIM: JPrevost
  • Holley 670 TB unit w/ 1/2" spacer/adapter
  • Edelbrock RPM vortec intake
  • 350ho 330hp vortec crate motor
  • 8" harm. balancer
  • Stewart stage 2 water pump w/160 thermo
  • SLP tri-y headers to full 3"
  • Rebuilt trans w/ SLP shift kit
  • Centerline 16x8's all around
  • 36/24 mm sway bars
  • Full poly bushings, even motor mounts
  • SLP LCA and panhard
  • Alston SFCs
  • Edelbrock 3 point STB
  • Global west steering brace aka wonderbar
  • Eibach pro kit springs
  • Bilstien high perf. struts and shocks
  • All this and I still have AC
My websiteAny questions?
Old Apr 17, 2001 | 03:50 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
<font face="Verdana, Arial" size="2">Originally posted by Stormshadow GTA:
and if i remove the egr walls behind the throttle body will that mess the egr up .or will it just free up a lot of airflow for me</font>
Shouldn't cause a problem, and it does free up some flow, it does reduce turbulance also.
HoosierinWA
Oct 7, 2015 10:15 AM
jaridjohn
Oct 5, 2015 07:01 AM
djmarch
Oct 2, 2015 10:41 PM
meeklay812
Oct 1, 2015 03:46 PM
