oil in cylinder head intake ports = bad? *Pictures*
Car: 87' Iroc
http://www31.addr.com/~stealthe/irocz/rebuild/valley/
Some of the pictures aren't too good, but the first one probably show it the best. My intake is perfectly clean, when I popped it off I noticed that the intake ports on the heads were black, is that oil residue? Was oil leaking from the valley into my heads?
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
probabily from all the silicon around the intake gasket.
Back off on the silicone. you only need a little around the water ports and a dab in each corner where the China walls meet the port face. And a bead along each china wall if you don;t use rubber end gaskets.
Silicon tends to float. (especially on an oily surface) and gets sucked in by the manifold vacuum.
A felpro 1255 vortec gasket is plenty thick and will seal up the intake ports without silicon or RTV around the ports.
Car: 87' Iroc
Okay....but the black residue in the ports on those pictures....it's definately oil correct? I was getting blue smoke out the tailpipes randomly.
Now the oil was coming from the lifter valley correct? Does this mean, if the intake ports on the heads were sucking oil, that I had a vacuum leak as well?
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
"if the intake ports on the heads were sucking oil, that I had a vacuum leak as well?"
yep.
like F-BIRD'88 said, back off on the silicon.
i don't use the rubber end gaskets myself as they tend to come out, so i only use silicon on the valleys where the intake sits at.
i don't use silicon around the water ports unless they are pitted.
where you do use silicon at, make sure the metal is clean & dry,
i use brake clean for that.
i don't fire it up right after i get it put together either, i like letting it sit for a minimum of 5 or 6 hours after i get done to give the silicon a chance to cure, over night is even better.
i only use permatex ultra copper on my motor.
looking at the other pics, it looks like you have an exhaust valve seal leaking some,
http://www31.addr.com/~stealthe/iroc...n/DSCN0112.jpg
yep.
If you get oil in the intake ports but the intake manifold runners themselves are clean (no oil) then it's often the intake valve guides/seals leaking oil. You would think it would just get the area near the valve oily, but I've found from experience that it works it way up the intake port, but not generally into the manifold.
Car: 87' Iroc
I know my valve seals are leaking....I'm going to replace them.
Engine: LT1, L400
Transmission: ZF6, T5
Axle/Gears: 3.45, 3.31
Originally posted by 89rocs
All that green is causing it
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
thanks dude.
now i know what im getting for lunch... a lime-aid from sonic......
anyhoo, yea, i bet that is your problem. its sucking oil from the valley.
Transmission: 4L80E/4L80E
The first thought that comes to my mind when I see some of his pictures is, "Get out of my swamp!"
Car: Formula
Engine: 6.0 LSX
Axle/Gears: 9 Bolt 3:27
I had same problem. The screw in stud holes were drilled into the intake ports and when i screwed down the studs, oil was seeping back then into the intake ports.
NinjaNife
Aug 23, 2015 11:49 AM
Navy8125
Aug 21, 2015 09:32 AM
