Ideal spark plug gap?
Old Jul 17, 2004 | 07:09 PM
Gunny Highway's Avatar
Car: 91 RS
Engine: 350 TBI
For my brand new 350 TBI I picked up some AC Delco plugs today. I was wondering if yall have any advice as to what to gap them at.
Vitals:
Trick Flow aluminum heads 23*
Crane HI-6 ignition box
MSD coil and wires
I believe stock is .035, but maybe .045 would be better?
. . and no nitrous will be used.
Old Jul 17, 2004 | 07:47 PM
8Mike9's Avatar
Car: 89 IrocZ
Engine: L98-ish
:::::::180 HP - 263 lb/ft (open element & advanced timing) ::::::
I'd run the stock recommended gap
Old Jul 18, 2004 | 01:22 PM
iroc-si's Avatar
Car: 1985 Chevy Camaro IROC-Z
Engine: 350ci from 79camaro
Transmission: 5 speed manual on lsd
The MSD instructions tell you to add about 0.1 to the gap so that would make 0.45.
Thats what I run and it worksa treat. Some folks can get away with running up to 0.55 but I think 0.45 is about what you want.
Si.
Old Jul 19, 2004 | 03:45 PM
Tremo's Avatar
Car: 88 IROC-Z - original owner!
Engine: LB9 with K&Ns, MSD, Foil, Taylor
Transmission: WC T-5
Axle/Gears: BW 9-bolt, 3.45 posi
Uhh, not 0.1, but 0.01. You surely don't want a half-inch gap. Since he has a hot ignition box that will probably fire anything, I'd try going from the stock .035 to maybe .040. Try it there, see how the motor likes it. You might try .045 next time.
Old Jul 19, 2004 | 04:50 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
I believe those are the figures for the stock 305 he swapped out and now hes asking about his modded 350 which he indicated in his post.
Old Jul 19, 2004 | 04:52 PM
iroc-si's Avatar
yeah sorry did indeed mean 0.01", but that is indeed what the msd instructions said. But yeah 0.040 would be better than 0.035".
Si.
Old Jul 19, 2004 | 05:08 PM
Car: 91 RS
Engine: 350 TBI
I went with .045 guys. I'm trying to do it once, because there's NO WAY I'm getting those suckers out after it's in the engine bay.
Those numbers are indeed with the 305.
pjsparts
Oct 29, 2025 06:39 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
Jlanz55
Sep 9, 2015 09:09 AM
Gunsbee
Sep 7, 2015 07:10 PM
