speedometer broke
Old Jul 18, 2004 | 10:48 AM
1989camarorsrs's Avatar
speedometer broke
about a month ago my speedometer stoped working until i drive for about 10-20 minutes, then when the carsa all warmed up it starts to worka gain
Old Jul 18, 2004 | 10:37 PM
steve8586iroc's Avatar
Have you checked the wires for the vss where it hooks to the transmission? Sounds like a wiring issue to me.
Steve
Old Jul 19, 2004 | 08:00 AM
ponykiller1992's Avatar
Car: 89 formula 350
Transmission: Stock 700r4
I had this same exact problem. It turned out that the gear on the VSS was worn, so it would just spin in place, causing the speedo no to get a signal. After a little while, it would heat up and cause to expand a little, then start working. I had to replace the VSS to get it to work right. Does your odometer move? Mine didnt until I changed the VSS. Damn 50 dollar part.
Old Jul 19, 2004 | 10:31 PM
Or a worn gear issue.
Steve
$750 L98
Feb 1, 2025 02:25 PM
InfernalVortex
Apr 20, 2021 11:31 AM
JSDaddy189
Interior Parts Wanted
Oct 6, 2015 02:22 PM
bjpotter
Oct 4, 2015 07:48 PM
sjorgens
Oct 1, 2015 07:54 PM
