if you have an MSD ign. box please read
Old Apr 17, 2001 | 02:07 AM
mtx28's Avatar
Well, i finally got a working MSD 6A(first one didnt work, and had to send it back for another) box, and have it installed on my carbed 383. when i removed the module and capacitor from the distributor and put the two wire harness in its place, i figured there might be a problem keeping it away from the spinning rotor. well, i started the car and it ran fine, so i assumed(shouldnt have) that the wires had somehow kept themselves away from the rotor. I drove it a week or two, and on my way back to school, the car quit. I figured it was the wires in the distributor, and sure enough, the rotor had slowly eaten through them. now, i know i dont get any smart-guy points for this act i pulled.. but has anyone else installed a box on a vacuum advance distributor and had this same problem? the only solution i can come up with is to cut a small piece of aluminum(very thin, i got a piece from my grandfather who has extra sheet metal from when he built his plane) and screw it down on top of the wires using the hole that previously held the capacitor down. now, if that made any sense, then please share your solutions..
  • 83 Z28--ttops, 200k miles--very ragged out. sold, thank goodness
  • 74 Z28--slightly modded 383, TH400 tranny, not too quick but fun to drive
Old Apr 17, 2001 | 02:25 AM
burnoutrpm's Avatar
have a 6al did it works fine. i did the solution you suggest...way ahead of you!! that "should" work fine! oh if you havent already,.. get some aftermarket 8mm wires.
89 firebird formula
356 10.5:1compression CURRENTLY DEAD!!! BEARING FAILURE!!
comp cams xe262 cam
performer rpm intake
#1405 edlebrock 600
sportsman 2 heads 64cc 2.02/1.60 valves 200cc intake runner
msd 6al
h.e.i. proform 50,000 volt vac. advance ditributor
700r-4 with 3.08 first gear and 3.23 posi 7 5/8 rear end.
b trans shift kit(will kill shifts...suck dong!!)
shorty heddman hedders with custom 3" pipe y-pipe back(no damn cat!) with 40 series flowmaster!
future mods: 406 roller REALLY REALLY REALLY RADICAL!!!!!
current engine underway..sucks not having a car!! Building the same engine but .060 over balanced and blueprinted..decided to get a little more serious this time around!!
Old Apr 17, 2001 | 02:51 PM
bottledpower's Avatar
Car: 85 IROC
Transmission: 700 r4
i used a screw and washer to hold mine down, no problems so far. use the hole that held the old module in.
85 IROC 350 11:1keith blacks,.555lift erson roller cam,1.5 crane roller rockers,edelbrock intake,holley 4150 750dbl pumper, nitrous oxide,full length heddman headers,true dual exhaust, 11"stall converter, 700R4, 3.73 locker
Old Apr 17, 2001 | 03:32 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
The few that I have installed with the harness came with a loop and screw to hold down the wires. Maybe they didn't include them in your kit??
Old Apr 17, 2001 | 09:32 PM
mtx28's Avatar
not that i saw.. maby i over looked it. in either case, this is really agrivating as now i got to get another harness, its just a small piece, but important nonetheless.
BRoss99
Aug 10, 2025 05:08 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Thornburg
Aug 30, 2015 08:05 AM
overdriv
Aug 20, 2015 03:52 PM
midias
Aug 15, 2015 05:07 PM
