air conditioning and performance
i have a 92 Z-28 and i never use the a/c since i have "t" tops. would it gain me and more horse power if i disconected the a/c belt or took the a/c out all together?
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I would say that it probably wouldn't be enough to notice, and there may be a day that you decide you want to use the A/C.
Working on:
'84 Z28 LG4 305 with 200,000 original miles!
Added dual elec fans.
145 MPH IROC Speedo
Building 430 HP 350 (ZZ430)
using primarily GMPP parts.
Short block sitting on a stand. (Man, those Fast-Burn heads sitting on it look good!)
Starting to look like the Kicker poster child!
ASE Certified Master Tech
Working on:
145 MPH IROC Speedo
Hey, taking the belt off will give you a few more horses, only a couple at the lower end of the rpm range, but quite a few probably 10+ when you get up in the high rpms and that things starts to cause serious drag. Taking the whole system out on the other hand can effectivly give you more power too. The whole system is probably 30+ pounds. This is a nice weight decrease so you will gain something from that too, not to mention free up some more room in the bay. Just be sure you really don't want to use it, and be careful when taking out the gas. Have fun.
87 GTA 350 L98
K&N filters, beefed up TH-700r4, Accel Manifold, Ported Plenum and Runners, Fuel Press. Regulator 49.5psi, air foil, modified MAF, SLP cold air box, Hypertech Thermomaster chip w/160 thermostat, MSD 6AL and Blaster 3, B&M shift kit & megashifter, Moser Ford 9in Rear with Richmond 3.50 and locker, Edlebrock TES headers and Cat Back,Hotchkis setup in rear, Poly suspension and Koni in the front, relocated MAT, bypassed TB coolant, 300 lbs lighter
Fastest ET's
Stock-0-60 6.8, 1/4 15.0 @ 94
Best-0-60 4.7, 1/4 12.8 @ 112
Norm-0-60 5.2, 1/4 13.2 @ 108
87 GTA 350 L98
Fastest ET's
There are a lot better ways to get back the extra ½ HP at 4,500 RPM than to take off the AC belt. When teh compressor is not clutched in, the sheave is basically an idler, and the only drag is created by belt friction and the inertial drag of the extra sheave. When shifting, the mass may actually help a little,like a heavier flywheel can actually increase speed.
Later,
Vader
"What a Day..."
Adobe Acrobat Reader
Later,
Vader
"What a Day..."
mdtoren
Aug 16, 2015 05:45 PM
